Ideal HP290 14kW ASHP - how to optimise
due to the continuing high-pitched noise through the pipesPosted by: @cmartinbwmba
Hi
You can get a stethoscope for less than 10€ on Amazon to listen to your pipes.
Candidates are heat pump compressor, fan, circulator or circulators if you have several.
Then turn off circulators one by one, then turn off heat pump with the thermostat. It'll probably stop the compressor immediately then still run the internal circulator for a few minutes. Same when it starts, the circulator will start then run for a few minutes, then the fan, then the compressor starts. So you can find the culprit depending on what's on when the noise appears.
If vibration comes from the heat pump and travels through pipes you can put in a flex hose in between to stop propagation. Another culprit can be a bit of junk stuck in a circulator impeller.
- 167 Online
@trebor12345 It's not marked if it is the required c ...
By Batpred , 1 hour ago
As I said I cannot access the installer portal, but my ...
By Odd_Lion , 1 hour ago
RE: Advice on potential HW Cylinder size
I think the comment about heating from cold is quicker ...
By sjcsystems , 2 hours ago
I went through heat geeks I chose Liam and Ben from ...
By Vinma , 2 hours ago
RE: Ideal HP290 14kW ASHP - how to optimise
Hi You can get a stethoscope for less than 10€ on Ama...
By bobflux , 2 hours ago
Greetings, I'm from the southeast of France. I am ren...
@editor Hi Mars Just reading the ultimate heatpump...
By Travellingwave , 5 hours ago
@tasos as above the pump is always running... Thanks ...
By benson , 5 hours ago
Still on the agile costs.. Distribution costs in Y...
By Batpred , 5 hours ago
Your DT is to low, you do not have enough heat exchange...
By ASHP-BOBBA , 5 hours ago
I am aware. But is your chart direct from a Pace BMS ap...
By Batpred , 6 hours ago
RE: Call for heat on open loop weather comp system
I don't know Grant system but most ASHP are very simila...
By ASHP-BOBBA , 6 hours ago
@painter26 — good idea. Please do let us know what he s...
By cathodeRay , 7 hours ago
@robs — thank you for your as ever valuable comments. T...
By cathodeRay , 8 hours ago
RE: Our Experience installing a heat pump into a Grade 2 Listed stone house
I beg to differ. I really could not make any useful pre...
By cathodeRay , 9 hours ago
Yes, but I need to reopen the battery box.. I just noti...
By Batpred , 11 hours ago
RE: The Hidden Secret to a Successful Heat Pump: Pipe Size Matters
If your heat loss is only 4kW and the pipes leaving the...
By JamesPa , 15 hours ago
My 2 bed mid-terrace definitely dropped consistently af...
By RadWhisperer , 19 hours ago
With complete radio silence from Peak and no sign of th...
By DaveC , 1 day ago
No you arent, because you dont need any, and furthermor...
As I mentioned earlier most radiators have a power outp...
By Batpred , 3 days ago
By DavidB , 3 days ago
