Heat pump domestic ...
Heat pump domestic hot water.
4 Users
2 Reactions
(@david999)
Topic starter   [#1719]
Quiet on here so thought I would jump on. What is your consumption when heating domestic water, mine is 5.2kw at the min. 16kw  pump.
(@Anonymous 5011)
210L 2 heats to 50 degs today, total used 2.6kW. if it heats once 1.4kW
(@david999)
@johnmo I guess it depends on how much water I use whilst I’m splashing about like a bear.  But it fair heats it up quick. This year will be the year to test it all out properly.
(@Anonymous 5011)
@david999 you need to include some specifics, your figure could heat up a thimble or a lake, pretty meaningless really.
Posted by: @david999
5.2kw
That is a heating power, but I assume you mean 5.2kWh?
(@david999)
@johnmo yup exactly, you are correct, no idea how that could be done and I was just wanting a ball park figure.  When the heat pump kicks in after a shower it registers 5.2kwh on my app, and was curious what other folks did.  Not how much or how long it ran just what it uses as it’s running in anger.  Hope that makes sense now.
(@steve81uk)
Over the last 6 days we've done 8 re-heats up to 42degC on our 300l cylinder.
Total energy consumed: 13.853kWh [1.732kWh per re-heat]
Total heat energy output: 70.147kWh [8.768kWh per re-heat]
Average power consumption: 831W
Average heat power output: 4.209kW
We’ve got a 16kW unit as well, and we’re seeing similar results to yours at around 5.5kWh for hot water at the moment.
Free UK shipping.
📘 From Zero to Heat Pump Hero
🛠️ Bodge Buster
New to heat pumps?
(@Anonymous 5011)
Posted by: @editor
Seen similar mentioned for big Vaillant units. I would consider doing a comparison trial just heating with the immersion and compare. Also double check against the electric meter, to check what you see is real.
(@david999)
I thought it needed the immerser to heat the water up to 55c but it seems to be doing it all through the heat pump, which surprised me.  I have my flow set at 35c and see how it fairs through winter, I’m happy with a home temp of 19-20 so might lower the flow temp a bit yet.
(@david999)
@editor thats great, I guess it will require a winter run before I gain confidence in my system. It really was a train wreck last year.
(@Anonymous 5011)
Possibly why you use so much electric, likely the heat pump is starting the immersion as it's not capable of getting there on its own. Turn the demand temperature down for DHW to 50 or below.
Looks like you need to step back a little to get the system set up correctly - otherwise you may need deep pockets to lay for the bills.
so not running weather compensation?
(@david999)
@johnmo not bad at the minute, 2 quid a day for electricity.
Page 1 / 2
