Coat tailing on this thread. I'm having a 5kW Vaillant put in and our house is only 3 bed (for idea of size). The installer has said two pumps on the heating system may be needed. It doesn't sound right to me but any help appreciated!
Posted by: @samiebon1Coat tailing on this thread. I'm having a 5kW Vaillant put in and our house is only 3 bed (for idea of size). The installer has said two pumps on the heating system may be needed. It doesn't sound right to me but any help appreciated!
It's unlikely you need 2 pumps, did he say why?
Posted by: @samiebon1@jamespa I think because they usually put buffers in and i've specified no buffers.
Well that's not really a reason.
If he had said "because the index circuit has a resistance that is too high for the water pump" that would be a reason.
Is there any reason to suspect the resistance in your system will be high like small diameter, circuitous or extra long pipework?
Posted by: @samiebon1I think i'll ak him about the index circuit. My own concern is the amount of 90deg elbows in my system!
Maybe best not to sound too clever, it might upset him. You might be better first to ask why he thinks you might need 2 pumps and then, if necessary, ask a follow up eg how he is going to ensure a second pump is fitted if and only if its actually needed.
Personally I doubt many plumbers calculate the index circuit not least because it's often not visible. I'm sure many if not most just assume the pump will be good enough which, in reality, it usually will.
Of course putting in loads of 90 degree elbows isn't best practice!
For those that having the thread, here's the latest video from our podcast series on buffer tanks:
I wonder how much efficiency it really costs - if there is unnecessary mixing it results in higher return temps so a "saving" on the next heating. Clearly there will be some heat & efficiency loss but perhaps not quite such a big problem?
I suspect in most cases it will not be worthwhile removing an existing buffer tank.
But on any future installation I would definitely question necessity if proposed as part of installation.
LG Therma V 16kw ASHP
Underfloor heating + Rads
8kw pv solar
3 x 8.2kw GivEnergy batteries
Manual changeover EPS
MG4 EV
Posted by: @tim441I wonder how much efficiency it really costs - if there is unnecessary mixing it results in higher return temps so a "saving" on the next heating. Clearly there will be some heat & efficiency loss but perhaps not quite such a big problem?
15% or more typically
The problem is not loss of energy (which as you say is small) its reduction in flow temperature to the emitters (due to the mixing) which means that the heat pump must be operated at a higher flow temperature than would otherwise be the case.
@jamespa There again, I have my secondary pump set to match the average flow rate from the heat pump system; this is 15 lpm. When the pump speeds up (as it does periodically) to as much as 30 lpm for a short time, my secondary pump connected to the output of the LLH does not change. Efficiency loss? Regards, Toodles.
I doubt I could get my weather compensation curve any lower so must conclude my buffer is not hurting me tooooo much. Certainly accept the main point that buffer tanks are likely unnecessary.
My settings:
Leaving Water temp 30/45
Outside temp -4/15
Currently outside temp 6 deg. LWT 36 deg. Indoor temp 21 deg
8kw pv solar
MG4 EV
@tim441 if you want to you can work out roughly how much it's costing by measuring the temperature drop across the buffer flow to flow. The cost is roughly 2-3 percent per C (more according to some, but I think the argument for more depends on deltaT flow to return being higher (than the typical 5C) on the emitter size.
It's entirely possible to set up buffer tanks not to mix, but unfortunately most installers appear not to do so, or fit a buffer tank that is to small to stratify. Of course some do, @toodles has for some while reported a buffer tank that doesn't mix to any great extent.
The real point is that they shouldn't be fitted in the first place because they are, in almost all cases, superfluous. Obviously once they are there it's a different calculation.
British Gas Heat Pump Installation Complaint
4 months ago
Heating Turned Off but Radiators Still Warm
4 months ago
Samsung Heat pump with Yonos Pico circulating pump running all the time
4 months ago
Samsung 5kW R32 Monobloc Gen 6 ASHP
5 months ago
Ideal Logic 10kW Heat Pump Pipes Noisy and Very Expensive to Run
1 year ago
- 258 Online
By Batpred , 26 minutes ago
I get the scientific argument however I would ask what ...
By JamesPa , 31 minutes ago
By Sheriff Fatman , 33 minutes ago
By Batpred , 52 minutes ago
By IRMartini , 1 hour ago
By GC61 , 2 hours ago
By cathodeRay , 4 hours ago
By cathodeRay , 6 hours ago
By JamesPa , 17 hours ago
By Batpred , 18 hours ago
By cathodeRay , 18 hours ago
By DavidB , 21 hours ago
By Batpred , 22 hours ago
By JamesPa , 24 hours ago
