ASHP heat output mo...
ASHP heat output monitoring
4 Users
3 Reactions
Posted by: @tim441
@jamespa I run 24x7 with weather compensation. So flow temps will normally increase at night
Thats true.  Ideally the FT could go up a bit further ie above the level required simply to sustain target indoor temperature, but not all heat pumps support this; fortunately with a night time cheap rate the tarrif lows and the consumption highs coincide naturally!
Posted by: @tim441
As my ashp was a retrofit I use simple digital thermostats to manage the target temp increase overnight.
As it works for your case that's great.  My only reservation (in the more general case) is if thermostats are causing daytime cycling.  That's why the recommendation is generally to set them a couple of degrees above the target so that they act as limiters not controllers.
Everything in this game is a bit house and person specific, the best general approach is almost certainly to start somewhere generically sensible, and tweak if there is a good reason.  Unfortunately plenty of heat pump setups reported here (which of course is a distorted subset of the total population) dont start somewhere sensible!
(@carlo)
@tim441 Out of curiosity, how big and how well insulated is your house? And do you have any idea of how many of those 16kW you actually use at peak?
I tried quiet mode (it is still in it) and I also put the current limiter. Before that when it started it had peaks of 6(!) kW, now only 4.5.
10kW PV
14kW LG Therma V ASHP
Induction heater
(@tim441)
Honorable Member Contributor
@carlo the 16kw rating refers to output.. afaik?
So we might expect COP around 3.5 and therefore draw around 4.5kwh?
I think I occasionally see that sort of draw in winter - especially if heating DHW to higher temperatures. But I believe my "normal" usage running the heating on AI is running around half that - or less.
I can see my annual use is 5800kwh for heat pump as it has a dedicated meter. Peak months around 1000kwh so perhaps averages 30kwh per day. But of course coldest days if freezing temps day and night we might use say 80kwh?
I don't monitor day by day - only monthly. We are in SW England where winter is generally relatively mild.
House is complicated! Total 200 sq m. Half is ancient building of stone, single glazed with poor insulation. Half is modern with excellent insulation. We heat the modern part to 21 deg as well as kitchen in old part. Remainder is heated to much lower temps as not needing higher.
LG Therma V 16kw ASHP
Underfloor heating + Rads
8kw pv solar
3 x 8.2kw GivEnergy batteries
Manual changeover EPS
MG4 EV
(@tim441)
@carlo I see there is a discussion in Facebook user group. May be useful to read fully the comments - no easy answers!
Screenshot 20250815 111555
8kw pv solar
MG4 EV
Page 3 / 3
