Posted by: @jeffIt says the infra and boilers are ready in the pilot. The infra has been built and homes are being connected after Xmas. Safety reviews have been passed. The pilot includes offshore wind producing hydrogen.
Hydrogen boilers for domestic use are entirely a fossil fuel industry con so far as I can understand it. To produce green (ie carbon free) hydrogen you need to use electrolysis (ie electricity) with a conversion efficiency of about 70%. If you used the same electricity to power a heat pump you have a conversion efficiency of 300%. It simply doesn't make sense for domestic heating so far as I can see.
That's not to say hydrogen doesn't have a place, in energy storage and for applications where you need a very high energy density and high temperature applications, but never for domestic heating so far as I can see.
If someone can explain the economics differently Im prepared to change my mind.
Posted by: @roblA more joined up approach would be to somehow decommission gas in areas where the network would have been upgraded, offering heating replacement schemes (don’t ask me how it would work). It seems to me that replacing old pipes now is doubling down on the wrong tech.
Or in areas where there is curtailment of renewables because the transmission network needs upgrading, suck up that energy close to source.
Of course there will be pensioners on the front page of The Daily Mail and it will be a big catastrophe, but change is rarely easy.
Posted by: @scalextrixPosted by: @roblA more joined up approach would be to somehow decommission gas in areas where the network would have been upgraded, offering heating replacement schemes (don’t ask me how it would work). It seems to me that replacing old pipes now is doubling down on the wrong tech.
And therein lies the problem. A higher proportion of pensioners vote than is the case for the general population.
As you say change is rarely easy, democracy makes it more difficult!
Posted by: @jamespaPosted by: @scalextrixPosted by: @roblA more joined up approach would be to somehow decommission gas in areas where the network would have been upgraded, offering heating replacement schemes (don’t ask me how it would work). It seems to me that replacing old pipes now is doubling down on the wrong tech.
The idea of converting whole streets to heat pumps and decommissioning gas was discussed on an ovo forum a few years ago, the ovo position was they were not supportive given the need to give customers choice. It was a suggestion I raised in the group. I can't remember if @transparent was still on the ovo forum at the time. I don't know if the ovo position has changed. It is not an open forum.
Posted by: @jamespaTo produce green (ie carbon free) hydrogen you need to use electrolysis (ie electricity) with a conversion efficiency of about 70%. If you used the same electricity to power a heat pump you have a conversion efficiency of 300%. It simply doesn't make sense for domestic heating so far as I can see.
May I reference the Green Hydrogen production project occurring at Langage Business Park near Plymouth...
There are multiple way in which this green-hydrogen might be used
- the existing CCGT generation plant at Langage
- two mining/minerals companies in the area who have signed contracts to access the hydrogen
- the industrial park being built beside Langage, which is within the Plymouth Freeport zone
The Plymouth Freeport is booming, mainly as a consequence of innovation companies working on products which have dual-use military/civilian potential.
Waterside space is at a premium due to heavy investment from MOD into autonomous naval capability, both above and below the waves
and the National Drone Hub which has an 8000km² offshore test area in order to accelerate the flight certification process
Posted by: @scalextrixOr in areas where there is curtailment of renewables because the transmission network needs upgrading, suck up that energy close to source.
... which is indeed the case in Cornwall and the western half of Devon.
There is major over-supply to the distribution grid in the area, with the majority of the 33kV and 132kV routes being under voltage constraint or thermal overload.
Posted by: @transparentMay I reference the Green Hydrogen production project occurring at Langage Business Park near Plymouth...
I know and thats what I said!. My comment was
Posted by: @jamespaHydrogen boilers for domestic use are entirely a fossil fuel industry con so far as I can understand it. To produce green (ie carbon free) hydrogen you need to use electrolysis (ie electricity) with a conversion efficiency of about 70%. If you used the same electricity to power a heat pump you have a conversion efficiency of 300%. It simply doesn't make sense for domestic heating so far as I can see.
Do you have an argument against that?
Im very much not against green hydrogen, I'm for it. Im just against the con that is hydrogen (or 'hydrogen-ready) domestic boilers (unless someone can tell me how it makes any sense)
Posted by: @jeffThe idea of converting whole streets to heat pumps and decommissioning gas was discussed on an ovo forum a few years ago, the ovo position was they were not supportive given the need to give customers choice. It was a suggestion I raised in the group. I can't remember if @transparent was still on the ovo forum at the time.
I wasn't active on that Forum when Kensa's Heat the Streets initiative was introduced.
Their existing heat networks aren't shown on NESO's Heat Networks section of the Nations and Regions Context resources for future strategic energy planning.
I've filed a 'memo' to ask that the Kensa GSHP networks be added.
The strategy is bound to increase in popularity because installation is free to commercial housing developers.
I don't understand the suggestion that OVO was unsupportive because they wanted consumers to have choice.
Each house on the estate can decide whether to have a connection to the heat network or not.
How have OVO misunderstood that I wonder?
Posted by: @transparentPosted by: @transparentMay I reference the Green Hydrogen production project occurring at Langage Business Park near Plymouth...
And I'm agreeing with you !
... but I added links to some existing practical projects using green hydrogen.
I didn't want readers here to imagine that using hydrogen was some far-off idealistic dream.
It's already happening.
@transparent no I have not misunderstood
This wasn't to do with the scheme you mentioned.
This was a conversation around not giving customers a choice. Converting a whole area and decommissioning the gas network.
I know about the scheme you mentioned.
Posted by: @transparentAnd I'm agreeing with you !
OK, perhaps you could have made that clear so that readers don't imagine that using hydrogen for domestic boilers is even faintly sensible (unless I am missing something which so far nobody here, nor in other places where I have made the same comment, has identified).
Posted by: @transparentI don't understand the suggestion that OVO was unsupportive because they wanted consumers to have choice.
Posted by: @jeffno I have not misunderstood
I hadn't intended to indicate that you'd misunderstood, but that OVO had.
Unfortunately I'm constrained by having to use text and a scattering of punctuation, which isn't the way my brain operates.
There are two 'hydrogen to the home' projects occurring in the Yorkshire gas supply area.
A Blended hydrogen trial is occurring in Gateshead with 600+ homers involved.
There's another area where the local authority were busy clearing streets of delapidated terraced houses with a view to running a hydrogen-only gas grid to the redeveloped area.
I can't find the reference to that at the moment.
Posted by: @jamespaperhaps you could have made that clear so that readers don't imagine that using hydrogen for domestic boilers is even faintly sensible!
Ditto.
My brain is struggling to convert a spider-web diagram of concepts and news stories into the text-based constraints of the forum
Posted by: @transparentPosted by: @transparentI don't understand the suggestion that OVO was unsupportive because they wanted consumers to have choice.
Which is the sort of thing that scares me. How can this ever be sensible/cost effective by comparison to fitting heat pumps, for the reasons set out above. This is just a con by the fossil industry! The fact that the Gateshead trial is adding just 2% Hydrogen seems like yet another confirmation (as if one were needed).
- 2,418 Topics
- 54.8 K Posts
- 369 Online
- 6,098 Members
RE: Is my Samsung gen6 outside air temp sensor missing a sheath/sleeve?
@papahuhu Im struggling to understand why they took a b...
By bontwoody , 6 minutes ago
RE: Reliable, easy to use home battery options
I can confirm that not only does it work without intern...
By Batpred , 1 hour ago
Are split ASHPs with R290 refrigerant coming soon?
Question. Are there any (or likely to be in the near t...
By iotum , 1 hour ago
Actually I am now finding that the return can be signif...
Indeed. In many ways, a defrost is a setback, with the ...
By cathodeRay , 1 hour ago
RE: Heat pump not reaching flow temperature
The good news is that it leaves no excuse if it doesn't...
By JamesPa , 1 hour ago
RE: How to use my Hanchu battery storage for home without it feeding back into the grid?
@countryman-helmsley In that case is there a button ...
By IRMartini , 2 hours ago
Thanks. Thats pretty much my intended route i...
By JamesPa , 3 hours ago
RE: Is it normal to use power from the grid when running off the battery?
The Solis S6 has various modes of use. I currently have...
By Batpred , 3 hours ago
RE: R290 and Foundation Air Bricks
I appreciate that the risk is probably proportionate to...
By L8Again , 3 hours ago
RE: Ideal HP290 14kW ASHP - how to optimise
Great. It’s not bad is it, though I agree it may repres...
By Davesoa , 3 hours ago
RE: Water outage in the the south-east
1: There are homes at the Lizard peninsula, SW Cornwall...
By Transparent , 4 hours ago
RE: Ecodan Pump Issues… Circulation pump turns off when heat pump compressor turns off
@f1p apologies, you are absolutely correct
By Patch321 , 4 hours ago
RE: Installer Fitted 9kW Instead of 11kW Heat Pump and Changed MCS Paperwork - What do I do?
Another good bout of cold weather should test whether t...
By JamesPa , 6 hours ago
RE: Samsung E101 Error Message and my ASHP Efficiency
@johnnyb amazing that the our forum is serving its purp...
By Mars , 18 hours ago
Best option for controller upgrade? - Grant Aerona
Fairly new heat pump owner - Grant Aerona 3 10kw - and ...
By Topher , 18 hours ago
RE: Daikin Wireless Thermostat
@toodles Yes. British Gas seems to have done an exce...
By Bash , 20 hours ago
Just a brief update to keep things transparent. Secti...
By DREI , 22 hours ago
I continue to receive emails from homeowners sharing he...
By Mars , 24 hours ago
@mrfield, welcome to the forums. Please go here and ...
