Our journey through Octopus tariffs 2020-2025
Everyone will have a different setup, usage, needs etc but it still might help others to see our journey from oil heating to ashp that will likely see us import over 14500kWh and export around 7500kWh this year - at a net negative cost.
Background
Somerset based
Listed Grade 2 building with large modern extension. Approx 100sq m old building & 100 sq m modern, well insulated
LG Therma V 16kw ASHP Installed Aug 2020
Underfloor heating throughout downstairs + Rads Upstairs
Fixed flow first 2 years then changed to weather compensation in winter 2022. Reducing heat pump usage from circa 8000kWk/pa to 5800 - saving 27.5%
8.7kw pv solar (2.2kw on FIT 2015 south facing, 6.5kw installed 2021 on east facing, low pitch)
3 x 8.2kw GivEnergy batteries installed 2021
1 x GivEnergy Gen1 hybrid 5.0kw inverter. Important to note max charge/discharge rate 2.6kWh that limits ability to take full advantage of cheap charging etc.
Manual changeover EPS
MG4 EV From 2023
WonderWatt used to help manage imports and exports
Comparisons
Comparisons are not easy due to changes in usage as well as:
- we did not record previous oil usage or cost. At a guess 2500litres/pa
- Move to weather compensation ashp Dec 2022 from fixed flows
- EV from 2023
- 2025 move to Intelligent Go meant batteries used more over summer to maximise cheap overnight imports and maximise exports
Rough numbers:
- ASHP uses 5800kWh/pa
- Solar prod 6500kWh/pa (7000kWh in exceptional 2025 and shading reduced)
- Exports prior to 2025 ~2500kWh/pa
- Exports 2025 ~7500kWh with forced emptying batteries. Income £1125 + FIT
- Imports therefore changed a lot to include additional battery filling at night for forced exports in summer + EV etc
- EV charging at home ~2500kWh/pa
- Fixed tariffs 2020 - Feb 2023
- Tracker Feb 2023
- Agile Mar 2024
- Intelligent Go Jan 2025
- Tracker averaged 16.15p - saving at least 20% vs standard/fixed tariffs
- Agile averaged 12.03p - saving around 50% vs standard/fixed tariffs
- Intelligent Go so far this year has surprisingly averaged 7.5p. Vast majority imported at cheap rates (overnight plus extra slots). Cost for full year likely to be ~£1100
- Faff factor is important. Hence use of WonderWatt to capture cheap slots on IG. Also used it for Agile to help manage. Also helps manage exports to maximise without running batteries down too much.
- At a guess oil would cost us ~£1500 pa now if still using.
So net import/export cost for us this year is roughly zero. Obviously capital costs need to be factored in.
Fwiw the heat loss calcs for heat pump suggested
27597 kWh of which 23800 was heating & 3800 hot water
Actual usage of 8000kWh on fixed flows might suggest average SCOP of just over 3? Our heat pump does not record SCOP
Underfloor heating + Rads
8kw pv solar
MG4 EV
That’s a great journey to read. We’ve all got different combinations of tech, purchased at different times. It clearly helps to have large roof areas pointing the right way!
@judith its interesting to see the 6.5kw array is at just 5deg pitch and facing east. I suspect they produce 90% or more of the production if they'd been optimal south facing on normal pitch. Luckily they're single storey high so i can clean them with brush and hose pipe. Dirt is therefore not an issue - if left uncleaned i suspect buildup of lichen and sahara dust etc would cause a problem over time.
The older array is south facing and around 40deg pitch
8kw pv solar
MG4 EV
Posted by: @tim441...
Now that would be a really interesting point to get clarified. I've never cleaned our panels and they're pretty much as clean now as they were when first installed, since the rain, sleet and snow do a pretty good job of cleaning for me. However, with your panels at just 5 degrees I can understand why there might theoretically be a difference.
I mentioned above
"2025 move to Intelligent Go meant batteries used more over summer to maximise cheap overnight imports and maximise exports"
A small reminder that there is a round trip loss caused by converting grid import to battery and re-export. I think most people suggest this is around 10%.
So with IOG imports at 7p+ vat and exported at 15p is still very worthwhile. Especially as i can do automatically for the most part. But of course will need to watch if export rates drop etc.
8kw pv solar
MG4 EV
2 weeks ago
EV+ Heat Pump Tarriff
3 months ago
4 months ago
Octopus tariffs - a quick comparison
5 months ago
10 months ago
- 576 Online
By cathodeRay , 26 minutes ago
By bobflux , 33 minutes ago
By bobflux , 2 hours ago
By Jonatan , 6 hours ago
By bobflux , 13 hours ago
By Batpred , 13 hours ago
By Transparent , 16 hours ago
By bobflux , 17 hours ago
By Toodles , 20 hours ago
By JamesPa , 23 hours ago
By Toodles , 4 days ago
