39 Users
158 Reactions
150.7 K Views
MK4
 MK4
(@mk4)
Greetings my fellow heatwave sufferers! Over here, we navigated May unscathed and we are bracing for June.
I wonder if I will live to see window shutters becoming the norm in the UK as they are in South Europe. Sooner than that I expect Mars and the users of the forum to open topics on using the cooling capabilities of the ASHPs. Till then and speaking from first hand experience, plain fans can be real relief.
Below is our May output. You can see that this year we had more overcast days in May. 1st of May in particular was like November…
IMG 9092
IMG 9093
Your energy: 38 kWh
@mk4 Here we are with June 2026 Solar production then; worst year yet - not by much but then, one must always look on the bright side I suppose!
IMG 6949
IMG 6950
IMG 6951
IMG 6952
Regards, Toodles.
(@chandykris)
Our June 2026 generation is down too. We generated about 630 kWh when compared to 690 kWh last year. This June is almost the same as 2024 June though. Last year was great for solar overall. Interestingly, the heat wave hasn't been helpful and seems to throttle electricity generation down when it's very hot.
16 * 435 watts PV
13 kWh Growatt battery
1 EV - Mercedes EQB
6 kW Aira Heat Pump
Bosch Induction Hob
Pod Point Solo 3 charger
(@papahuhu)
Your energy: 4 kWh
IMG 0295
You weren’t alone, we were considerably down on last month and last year. But now that flux is back the revenue is worthwhile again, so I’m a happy bunny.
This post was modified 5 months ago by Papahuhu
MK4
 MK4
(@mk4)
@trebor12345oodles Greetings! We have been hit by a failure, one of our strings went down mid-June and thus we are loosing the highest yield months….the installer was practically a middleman using subcos, the subcos have dispersed meaning it will be a while before operation is fully restored.
Luckily we still have some 8Mwh reserve already with the DNO and this should get us  through next winter unscathed.
How are you guys faring with the heat? We are reading some horror stories in the news (though mainly for continental Europe).
IMG 9177
IMG 9176
Your energy: 38 kWh
@chandykris Indeed, the elevated temperature does attenuate output from the panels quite significantly - in fact, you might say: Hot weather, they don’t like it up ‘em! Regrets, Toodles.
(@tim441)
Honorable Member Contributor
Not surprisingly July was best month ever
6.5kw system produced 1043kwh. Previous high 898 May 2025. 777 July last year
2.2kwh system 312kwh. 257 May 2025. 235 July last year
The hot weather probably reduced output significantly.  Maybe July sunshine in cooler temp woukd have resulted in up to 10% more even?
My son has a new system this year
8.5kw produced 1203kwh
This post was modified 4 months ago 2 times by Tim441
LG Therma V 16kw ASHP
Underfloor heating + Rads
8.7kw pv solar
3 x 8.2kw GivEnergy batteries
Manual changeover EPS
MG4 EV
(@chandykris)
What a month it has been for solar! We saw our best ever generation with excess of 700 kWh, even higher than last June. Sunny wise, probably June was better but the lack of 35 Celsius plus days meant our panels generated a lot more. We hardly dropped below 15 kWh in a day and consistently generating more than 20 kWh. With a few saving sessions thrown in when I could export from the batteries, we are on track for next zero bills from April to September.
Had I switched to Flux, we would have probably made more. Our batteries rarely drop below 85% to 90%. So, we could have avoided charging upto 100% from the grid and use only excess solar leaving off-peak only for the EV and hot water. But with constantly fluctuating gas prices, didn't want to switch to Flux and find that when we want to come back to Go or Cosy in October the prices have gone up a lot more.
16 * 435 watts PV
1 EV - Mercedes EQB
6 kW Aira Heat Pump
Bosch Induction Hob
(@tim441)
@chandykris slightly intrigued by your production...
You have a 7kw system?
Orientation and pitch? Shading?
My 6.5kw system produced 1043kwh.
East facing. 5deg pitch. No shading
South facing 45deg pitch. Some morning shade
I think the low pitch gets us suboptimal production but for more hours. So perhaps overall not as bad as people expect?
This post was modified 4 months ago by Tim441
8.7kw pv solar
MG4 EV
(@chandykris)
@tim441 Two reasons, the panels are South West facing. Plus, lots of clipping due to the 3.6 kW inverter. Our DNO approved only 6 kW export, and given our batteries are AC coupled that can export by themselves, we ended up with this design. If we were to start again, I would go for a larger 6kW hybrid option. Having said that, it's only in the peak summer months we see clipping. During other months or even when it's cloudy, the oversized panels help us generate more. Wish I had discovered this forum when we were in the process of installing our array.
This post was modified 4 months ago by ChandyKris
16 * 435 watts PV
1 EV - Mercedes EQB
6 kW Aira Heat Pump
Bosch Induction Hob
(@tim441)
@chandykris i think many of us would do things differently with more knowledge... and as tech moves forward
Our bigger system typically produces around 5100kwh/pa... last year 5500 which seems in line with the installer predictions
Smaller system around 1700kwh
Again the flat roof seems to out perform pitched on proportionate basis
We are capped at 6kw export which probably results in a little clipping. But hardly noticeable
8.7kw pv solar
MG4 EV
Your energy: 107 kWh
No great surprise given how relentlessly sunny, dry and drought-like July has been, but our 6.16kW solar array has just set a new monthly production record: 1.0MWh generated in July.
That is comfortably ahead of every previous July since the system was installed.
Not often I find myself wishing for rain while watching the solar numbers climb, but the garden would probably have preferred a slightly less impressive month.
IMG 0986
IMG 0985
Page 30 / 34
