Do I need to change...
Do I need to change the control unit when replacing my Ecodan Air Source Heat Pump
3 Users
2 Reactions
(@calumm)
New Member Member
Topic starter   [#3129]
I have a 16 year old Mitsubishi Ecodan (5kw) that has a large Flow Temperature Controller Unit ( PAC-IF021B-E) and a separate remote control unit for that (Mitsubishi branded) and a separate again timer (7 day 2 channel heating and hot water programmer - Timeguard brand).  My heatpump has developed a leak in the refrigerant, and the quote to test fot the leak is so high, that I may as well buy a new unit.  I have found an R32 unit at a good price, without the FTC unit.  I don't want smart controls or anything like that - I'd actively NOT want them.  Can I replace the heatpump and get it wired into my existing set up - or do I need to get a much bigger job done?  I've had an awful lot of house expenses this year, and desperately want to avoid any unneccessary costly system changes.
(@majordennisbloodnok)
Mitsubishi Electric
Hi, @calumm
Although I've got Mitsi kit myself, I must say I've no idea as to an answer for you. However, we're just having a quick heads-together to see if we can find one of our professional forum members who's familiar with that brand and might be able to give a bit of a response.
(@calumm)
New Member Member
Thanks so much. Tried speaking to Mitsubishi, but they won't respond on such things to a cusomer, as opposed to an installer. I've had bad experiences with installers previously, so want to know myself before I engage!
Mitsubishi Electric
Understood, @calumm. I'd also want to have done my research beforehand.
It certainly wouldn't surprise me if were to turn out it was possible to continue with the old FTC. I must admit it also wouldn't surprise me if someone in the know were to qualify that with good reasons why it might not be recommended; tech can move on quite a lot in 16 years. I only mention it for management of expectations, but if you don't ask you won't know.
Mitsubishi Electric
One of the other mods has just reminded me that @ashp-bobba knows Mitsi stuff, so may have a few thoughts. Any ideas, @ashp-bobba?
 F1p
(@f1p)
Unfortunately the answer is Yes you will need a new FTC.
There is some generational compatibility:
R410a refrigerant - FTC2 to FTC6 (PAC-IF07(1-3)B-E)
R32 refrigerants - FTC6 or FTC7 only
R290 refrigerants - FTC7
(@calumm)
New Member Member
@majordennisbloodnok   - thanks so much.  That has been really helpful. 🙂
Mitsubishi Electric
Kind of you, @calumm, but it was @f1p who did the heavy lifting.
Either way, glad you've got an answer. Pity the answer wasn't your ideal one.
Thank you
