39 Users
158 Reactions
150.7 K Views
Your energy: 38 kWh
And here is 2025 which chose to hide in the last posting!Toodles.
IMG 6881
Bang on
(@andris)
@toodles what a great month for solar! I love April as this is where my shading is gone completely. 1020KW
Screenshot 20260501 100006 mySolarEdge
Beat last year's production, which was the best for April till now.
(@papahuhu)
Your energy: 4 kWh
@toodles
When the clouds are gone and the leaves aren’t out it’s good. I was loosing 30% to clipping due to export limit at the back end of the month, just couldn’t find enough things to run to soak up the power. As soon as there’s a cheap V2G EV available with a decent capacity I’m in.
Your energy: 38 kWh
@papahuhu I have Enphase IQ7a microinverters on each of the 21 panels and at maximum production, they will clip by a few watts but I see peaks of ~7.1 kW. My G99 allows for 10 kW export but I rarely see more than ~7 kW and then those peaks are only for a few seconds at a time. With the current arbitrage on Cosy and Outgoing tariffs being less favourable than of yore, I only export that which I cannot consume locally now. The last call upon the grid for import was on the 19th. April and I am exporting ~15 - 25 kWh per day now. The Daikin heat pump is zzzzz’ing now and the Sunamp Thermino heat battery consumes ~3.0 - 4.5 kWh per day, we are an all electric home but the Air Fryer and the Induction Hob do not impose huge loads on the system. The Tumble Dryer is a heat pump model so the main energy eaters are the washing machine and the dishwasher I think. Of course, the main need for those multiple kWh’s is during winter when the solar panels are ‘resting’! I dread to think what we will be paying per kWh by then!!!☹️ Regards, Toodles.
MK4
 MK4
(@mk4)
On the contrary, I am happy to report that we have had a rainy April and thus a lower yield this year! Water reserves are on the rise and this is what we need in view of the upcoming summer.
I must admit however that having 9 degrees today (1st of May) is rather odd….Apparently we are experiencing a cold wave and I expect our ASHP to kick in this evening (it has not switched on as scheduled during the last few days, with OATs reaching mid 20’s during the day and IAT constantly above 20)
IMG 8888
IMG 8889
(@papahuhu)
Your energy: 4 kWh
@toodles The Scrooge in me is anxious over the winter too. Catch 22 is that I either fix for 12 mths now on a heat pump tariff at about 15p or wait in vain for a VPP to emerge from the chaos to make some profit. Mr Greedy is in conflict with Ebenezer, a lot depends on whether Millibands energy market measures work or not. The cynic in me expects the consumer to continue to be screwed over marginal pricing.
(@papahuhu)
Your energy: 4 kWh
@mk4 Must be that global cooling! I still vividly remember a documentary in the late 70s warning that the data indicates a new ice age is on its way. I recall it was Mr Spock narrating it, with London and NewYork under an ice sheet.
One day someone will tell the truth in that we only superficially understand our climate, and it is way too complex for our stone age climate models to predict. But I’m still good with burning less stuff, cleaner air and water is a massive benefit to humanity.
Your energy: 38 kWh
@papahuhu I hope to have a few months ‘grace’ over the summer before having to commit to any new tariff / renewal / contract or VPP package. It is not just that I shouldn’t have to pay anything BEYOND THE EXTORTIONATE DAILY STANDING CHARGE but I hope some common sense might prevail meanwhile. I’m not sure that I’m convinced there is much chance of this happening though. Regrets, Toodles.
Your energy: 38 kWh
@papahuhu Perhaps we should all be listening to Mr. Orangeman as it would appear (so he tells us) he knows all there is to know and that ’Drill Baby, Drill’ is just one of his commandments. We are all mere ignorant sceptics it would seem, anyway, who needs all those ‘windmills’?! Regrets, Toodles.
This post was modified 7 months ago by Toodles
(@papahuhu)
Your energy: 4 kWh
@toodles Im trying me best to ignore orangeman, I figure that is the most constructive and effective resistance. I had another look at one for the garden, even a 1kW unit at 10m would be a help. I spoke to planning last week but they told me once you have a heat pump even the smallest wind turbine requires planning approval. The irony is that the heat pump is the reason I need a wind turbine.
This post was modified 7 months ago by Papahuhu
Your energy: 38 kWh
@papahuhu Now May is out, I venture to cast a clout: Here are the solar yields for the last four Mays:
IMG 6899
IMG 6900
IMG 6901
IMG 6902
May ‘26 was not quite up to ‘25 and I put this down to the heat wave days causing a reduction in yield. The ‘24 yield is lower due to the installer having to return to correct the mountings of some micro inverters which necessitated the erection of scaffolding along with safety boards that caused some shading for about a month. Regards, Toodles.
(@papahuhu)
Your energy: 4 kWh
Here’s me. Found my output when I control the battery and export is slightly better than when IOF controls the export. Seems AI isn’t as smart as everyone says. Although my export was up 10% my income was down about 50% thanks to IOF still being unavailable, going to be touch and go whether I get zero power bills this year.
Had a trustmark audit too, they came up with a massive list of errors and omissions, including a main roof SWIP room in roof which is about £8k worth of work. All done at the installers cost, that should decrease my heat loss significantly this coming year. That’s a Brucie Bonus as I should be able to reduce my flow temp.
IMG 0285
Page 29 / 34
