Towns water feed to...
Towns water feed to air source heat pump system
2 Users
0 Reactions
(@davidalgarve)
Topic starter   [#2979]
As installed, my system had a buffer tank which I had converted to a return-line CH volumiser.
It was badly done and I now plan to improve the pipework by putting the volumiser in the CH flow and reducing the number of multiplex elbows, all with the objective of improving flow.
The towns water feed to pressurise the system is still as original, i.e. to the middle of the buffer/ volumiser tank, (as diagram below) but I am uncertain if this is still the best point for the towns water pressurisation.
The DHW flow is from the 3 way valve and its return taps into the main return to the Ecodan.
Comments would be appreciated.
Screenshot 2026 05 04 at 16.23.38
This topic was modified 6 months ago by Mars
2 x Growatt 7.5kW Batteries
Fronius EV Charger
Kia e- Niro 64kW
Posted by: @davidalgarve
Ultimately I doubt it matters much because pressures will inevitably equalise.  I would probably choose to put it upstream of valves just so there is no possibility of forcing a valve open, although even this isn't absolutely certain because there are of course two paths from any one place in the system to any other place.
Maybe someone else can come up with a reason why it would make a material difference, but I cant!
(@davidalgarve)
@jamespa Thanks James. As you say, the pressures should equalise.
I was contemplating teeing it into the return line to the Ecodan.
There does not seem to be the same need to pressurise the much simpler and shorter DHW circuit, but I suppose it can't be separated.
I do now see that I have no air bleed on the DHW heating coil circuit and this may need to be added.
Fronius EV Charger
Kia e- Niro 64kW
The DHW circuit cant be separated (well it could, you could use a plate heat exchanger, but why bother).
There needs to be an air bleed at every locally highest point.  I guess it might well be possible to plumb a DHW cylinder so it (or some part of its pipework) isnt a locally highest point, but its tricky!
