Harvest Thermal - ASHP with a smart thermal battery
Posted by: @springswoodOut of curiosity I dusted off my 40+ year old physics knowledge and tried to measure the heat capacity of my house. More of a very rough estimate. The equation is blessedly simple:
Heat Capacity (Joules per degree C) = Time constant (seconds) x Heat Transfer Coefficient (Watts per C).
Which all puts my heat capacity in the range 1.5-3.4 kWh/C.
Thanks for this, I didn't realise the equation was that simple.
I tried to get an estimate of mine a different way by looking at measured temperatures/gas consumption and lag times (I would have to look back to remember exactly how) and came up with 15kWh/C (+/- 5kWh/C). The method I used would have taken 4 cats, cooking and people into account, but has other problems. I came up with a similar value for another house on which I did some analysis and got to about 10-14kWh/C.
Reversing that back my heat loss at design OAT of -2 and an average IAT of say 20 is 7kW. Various heating sources are probably equivalent to say 3C temp difference (roughly 1kW), thus the heat transfer coefficient is 7000Wh/19C = 370Wh/C. If my heat capacity is in fact 15kWh/C = 54MJ/C then it would take =140,000s to cool by 37% (7C) = 40h. Im pretty sure that's quite a bit longer than it actually takes, even though the rate of cooling slows down as the house gets cooler. Thus my current estimate of heat capacity is probably wrong. That said I dont allow the house to cool to 13C very often (or at all), and it may well take longer than I think!
I do have data logging (because I have a heat pump and home assistant). Heat pumps measure everything and home assistant logs much of it) so could perform the experiment with the specific objective of measuring heat capacity. Im very tempted to do so next season.
- 2,815 Topics
- 1,878 Online
- 7,230 Members
Ah! So it's the electrochemical series which drives the...
By Transparent , 15 minutes ago
We've had an influx of new members joining the forums o...
By Mars , 38 minutes ago
@editor thank you that's a very useful reply. We've man...
By Brazilguy67 , 1 hour ago
By Chilli304 , 2 hours ago
By JanHarley , 3 hours ago
By JamesPa , 6 hours ago
By bobflux , 19 hours ago
By Toodles , 22 hours ago
By bontwoody , 3 days ago
