are there internal ...
are there internal electric heaters ?
3 Users
0 Reactions
(@ivanhoew)
Topic starter   [#2100]
Hi chaps ,
reading this ..
https://kronoterm.eu/how-to-set-up-your-heat-pump-for-maximum-comfort-and-minimum-cost/
i saw this bit ..
ashp leccy heaters .
i know there are lots of different makes of pump , but i wonder , is this a thing that most pumps do , meaning if , as i do , i run my pump at hs temps of 15-16c , i am possibly then using more kw than i would running it at 20c !
that would be an eye opener and no mistake .
regards
robert
Morgan
(@morgan)
As per the screen shot, when my Ecodan is not calling for heat and is effectively 'off', you will see that the flow and return temp' is always at a minimum 20c.
Screenshot (93)
(@ivanhoew)
Thanks morgan , i can't find any flat bits in my graphs ..
Heat Pump(9)
probably because i suspect  its about 6x too big , i can see looking at the amps line , there don't sem to be any spurious power surges in between cycles .
regards
robert
(@davidalgarve)
Interesting because when my Mitsu is not running I recall typically Phase A shows zero; Phase B 11.2W & Phase C shows 107.44W.  I thought it was the control plus the undesirable secondary circulation pump. It doesn't seem much for any electric heater on a 16kW ASHP
2 x Growatt 7.5kW Batteries
Fronius EV Charger
Kia e- Niro 64kW
(@ivanhoew)
i agree david , that sounds like a water pump sort of draw.
maybe its just that ashp make in the article that does it ..
