Octopus Cosy Heat P...
15 Users
60 Reactions
132.8 K Views
(@andrewj)
Octopus Cosy
@swwils mine is mostly off now.  Hot water for an hour 02:30 to 03:30 then heating to 21c from 03:30 to 05:30 although in reality it will only come for a short period to bring the house temp back up to that temp.  This is giving overall COPs of <4 with the OAT in single figures right now, but a quick calc of the heating only COP from this morning gives 4.08 at 7.4c.
What would be very useful is if you could describe your system, in some detail: how you have it set up, how you run it, hub parameters etc.
(@agentgeorge)
@swwils there is no logic to oversizing a heat pump. It wastes energy keeping a large compressor and heat exchanger running.
you got the 9kW cosy as the smaller 6kW was not suitable for your properties heat loss
its not just the COP you look at, its the energy consumption in kWh per day.
My Cosy6 was running full operation the first winter as i hadn't completed the insulation in the new kitchen extension roof.
This winter period, the Cosy6 was much quieter, insulation makes a huge difference to heat loss. My rear extension is fully insulated, floors, ceiling, walls, to 150mm. It is always 2C warmer than the rest of the house
This Autumn, after the wall insulation is installed in the Lounge/Kitchen I will be rebalancing the UFH towards the Lounge
(@swwils)
Firmware updates have massively helped with my cosy vibration/noise it seems to not run the fan that fast anymore. So very pleased 👍
Octopus customer service also great once the gears got turning
(@andrewj)
Octopus Cosy
Did you see the post on Facebook where an air conditioning module, plumbed into the wet circuit and powered by the Cosy was shown?  Only a prototype at the moment but it looks interesting.
(@swwils)
@andrewj I personally don't like domestic fan coils, people never clean the indoor units with cassettes let alone coils
Posted by: @swwils
You are right that people don't clean things but, If they want cooling then they will have to get used to cleaning, it comes with the territory.  Either that or suffer the consequences.
This post was modified 4 months ago by JamesPa
(@swwils)
@jamespa haha very true, although the engineer yesterday said that condensation would occur at 30C flow temp somehow 😂
Page 32 / 32
