Flexi-Orb Heat Pump Scheme: A Game-Changer for the UK's Heat Pump Industry
The UK’s heat pump industry has just been handed one of its most significant shake-ups in years. Flexi-Orb, the alternative certification scheme developed by Certi-fi Schemes Ltd, has officially had its Heat Pump Scheme recognised as fit for the purpose of accredited conformity assessment by the United Kingdom Accreditation Service (UKAS), putting it on an equal accreditation footing with the Microgeneration Certification Scheme (MCS) for heat pump installations.
For more than a decade, MCS has been the sole UKAS-accredited certification scheme recognised for government-backed renewable heating incentives. That monopoly is now over (at least in principle) with the arrival of a competitor that promises a fresh approach, greater installer support, and improved consumer outcomes.
A New Era of Choice
Flexi-Orb has been designed to address what many see as deep-rooted problems with the way heat pump certification has been handled under the existing system. For years, industry insiders and homeowners alike have voiced frustration over inconsistent quality, poor accountability, and a lack of meaningful performance benchmarks.
David Lindsay, Managing Director of Flexi-Orb, told Renewable Heating Hub: “We’re delighted to have secured UKAS Heat Pump Scheme recognition, which is the precursor to the formal UKAS ISO/IEC 17065:2012 assessment process, but this is just the start. Our mission has always been to put consumers first while making the compliance process fairer, clearer and more effective for installers. We’ve built Flexi-Orb with input from right across the industry, from manufacturers and installers to consumer advocates. This isn’t about lowering the bar; it’s about setting the bar in the right place and ensuring it’s achievable for those committed to quality. Now that we have UKAS recognition of the Heat Pump Scheme, we can move forward with the UKAS assessment process with real confidence.”
That industry collaboration has been key to shaping Flexi-Orb’s Heat Pump Code of Practice, which covers every stage from design and noise calculations to aftercare and performance monitoring.
Mark Nelson, Certification Director at Flexi-orb, who has been involved in the scheme’s development, believes the arrival of a second accredited scheme is vital for raising standards: “Certification shouldn’t be a tick-box exercise. It should be a living, breathing process that keeps installers sharp and protects consumers from poor workmanship. Flexi-Orb’s model brings real-world practicality into the standards, without losing sight of technical rigour. That combination is what the industry has been missing.”
Unlike the revised MCS process, which has stepped back from certain office-based assessments, Flexi-Orb insists on them. That means checks aren’t limited to what an inspector sees on-site, but also extend to the paperwork, permissions, and aftercare infrastructure behind each install.
The scheme also includes clear assessment checklists (something many installers have long called for) so everyone knows exactly what’s being measured and why.
Why This Matters to Homeowners
The introduction of Flexi-Orb as a UKAS-approved scheme could mean:
- Greater consumer choice: Homeowners will now be able to select installers certified under either scheme.
- Healthy competition: With two schemes in the market, both will need to continuously raise their game.
- Better accountability: Flexi-Orb’s feedback mechanisms and practical design focus could lead to fewer underperforming systems.
For a sector that has suffered from a stubbornly low average SCOP of around 2.7, when well-designed systems should regularly achieve 3.5+ – this could be the jolt the market needs.
Why This Is Big News
I’ve spent years hearing from UK homeowners on the Renewable Heating Hub forums, and I’ve lost count of the stories involving MCS-accredited installations that were poorly designed, badly executed and left consumers fighting through a bureaucratic maze to get anything fixed.
From systems that can’t heat a house in winter, to oversized buffer tanks destroying efficiency, to heat pumps short cycling themselves to death, these aren’t rare exceptions. They’re patterns. And the oversight structure has been failing to break those patterns.
That’s why Flexi-Orb’s UKAS approval is a huge deal. Not because it guarantees overnight change (it doesn’t) but because it finally breaks the monopoly that has allowed complacency to thrive.
However, there’s still a major hurdle: DESNZ.
Right now, the Boiler Upgrade Scheme (BUS) and other government-backed funding streams still require MCS certification for eligibility. That means even with UKAS approval, Flexi-Orb-certified installers can’t access the same grants unless DESNZ updates its rules.
If MCS is allowed to remain the sole gateway to taxpayer-funded heat pump installations, then we’re back to the same problem, a monopoly, just dressed in new clothes. And given that MCS themselves have publicly stated they want that monopoly, the competition risk here is obvious.
In any other sector, if a private body moved to lock out competition in this way, government watchdogs would step in immediately on anti-competition grounds. The fact it hasn’t happened yet in heat pumps is baffling.
What Needs to Happen Next
- DESNZ must recognise Flexi-Orb (and any other UKAS-accredited scheme) for public funding eligibility.
- Clear performance benchmarks must be introduced, for example, a baseline SCOP that every funded installation must meet.
- Accountability must be enforced, with transparent routes for homeowners to get poor work corrected without months of finger-pointing between schemes, certification bodies and consumer codes.
If that happens, UK homeowners could finally see a market where quality is rewarded, where grant funding goes only to competent work and where poor installers can’t hide behind paperwork.
The arrival of Flexi-Orb as a fully accredited alternative is the first step in that direction. Whether it turns into real, lasting change will depend on whether DESNZ (and the wider industry) have the courage to embrace competition and put outcomes ahead of gatekeeping.
Something’s happening behind the scenes that could have massive consequences for the renewable heating sector… and not in a good way.
The Department for Energy Security and Net Zero (DESNZ) has launched a consultation proposing that MCS becomes the only certification scheme allowed for government-backed schemes like the Boiler Upgrade Scheme (BUS). That means no competition, no alternatives, no choice for homeowners or installers.
This move would effectively shut out Flexi-Orb, a legitimate, UKAS-accredited scheme that has been working hard to provide installers with an alternative and that I’ve been very impressed with based on off record conversations I’ve had with them. Both MCS and Flexi-Orb are recognised by UKAS as operating equivalent schemes under ISO standards, yet the government is now pushing for a single, protected monopoly.
Let’s be clear: MCS has had years to raise the bar. Installer quality? Still wildly inconsistent. Consumer protection? Patchy at best, with scores of homeowner horror stories on these forums.
Rather than fixing these issues or welcoming healthy competition, they’re closing ranks and DESNZ seems happy to go along with it.
This isn’t about which scheme you personally prefer, it’s about making sure the industry doesn’t get locked into a single provider, with no recourse, no innovation and no incentive to improve.
How you can help.
DESNZ is running a public consultation and your voice matters. If we don’t push back now, this will become policy.
Fill in the BUS consultation form here: https://www.gov.uk/government/consultations/boiler-upgrade-scheme-and-certification-requirements-for-clean-heat-schemes/boiler-upgrade-scheme-and-certification-requirements-consultation-accessible-webpage
Deadline is 11 June 2025.
Response done, thanks for flagging this.
Yup, done.
Response sent. Thank you for highlighting the document.
Response sent yesterday
I am keen to see how this unfolds and changes the landscape, I for one would welcome the opportunity to have an option to which accreditation we hold as we have to pay with a lot of time and money to hold these, if it shows having the higher grade that you are a company that consistently delivers design and installation quality then bring it on as it will help us advertise that we are a cut above and standards are high rather than prices are low or corners are cut.
I must say I like the MCS badge and what they do but none of our customers have ever had a reason to contact them so our experience is just the MCS portal which is very easy to navigate. Seeing some of the horror stories on here I also think a consumer code that proactively pursues for reparations will shake up the poorer side of the industry, less ASHP bashing and mythical lies about them not working and less bad experiences for all clients one hopes.
MCS have set a potential trap in the new version of MCS020(a). The copyright notice prohibits it's use for commercial purposes other than by an MCS installer.
Now the document (or at any rate it's contents) is effectively part of planning law, so I'm not sure how a suit for infringement of copyright would play out in court. Hopefully this will never be tested but I fear MCS might go to some length to protect their monopoly.
Now that flexi-orb are accredited they must have a very strong argument that denz must change, and if denz don't then a strong basis for complaining about something close to misleading actions by denz.
As a potential heat pump customer, it would be good to have some alternative standards which consider the real-world cost and disruption resulting from the requirements, with more flexibility to come up with designs which provide a better balance between the heat pump system performance and the impact of the installation on the home itself.
Example is DHW cylinder sizing, where rigid sizing rules demand large cylinders, forcing them to be moved to inconvenient locations like garages, bedrooms, or other locations where they harm the usability of the space. There should be more flexibility for the home owner to decide if they would prefer a heat pump system which fits within the existing design of their home, accepting some compromises on system DHW capacity or performance.
As someone who has suffered from a Heat Pump installation backed by the MSC logo only on paper, without any help when things went wrong, I would love to see homeowners have other choices.
We all know how messy and inconsistent the renewable heating sector can be and how often homeowners are left picking up the pieces after poor installs or lack of proper oversight.
That’s why I wanted to share something important with you. Certi-fi have published an Open Letter to the Rt Hon Edward Miliband MP, raising urgent concerns about the future of fair competition in the renewable energy sector and calling for stronger independent oversight to protect both consumers and the industry itself.
This is exactly the kind of thing we talk about daily on these forums: transparency, accountability and making sure the industry actually works for homeowners, not just against them.
I’d encourage everyone here to read the letter and, if you agree with its message, add your name in support. The more voices behind this, the harder it is to ignore. You can read and sign here: Certi-fi Open Letter – Add Your Support
Let’s make sure homeowners’ experiences and concerns are represented where it matters.
The Myth of the MCS Performance Guarantee
1 month ago
UK Heat Pump Problems: A Complaint Process That's Irreparably Broken
1 month ago
5 months ago
9 months ago
- 733 Online
By bobflux , 22 minutes ago
By Fretless6 , 2 hours ago
By Jonatan , 5 hours ago
By bobflux , 12 hours ago
By Batpred , 12 hours ago
By Transparent , 15 hours ago
By bobflux , 16 hours ago
By Toodles , 18 hours ago
By JamesPa , 22 hours ago
By Toodles , 4 days ago
