Samsung Gen6 Settings - Remove Zoning
Hi,
I have a Samsung Gen6/Joule ASHP currently set with 3no. thermostats (1 per floor) controlling 3 heating zones (all radiators). I'd like to move to a single zone (or possibly 2?) controlled by the ground floor thermostat ("Thermostat 1") and use the radiator trvs to control room temps on the upper floors. The purpose of this is to
a) Increase the water flow to try increase efficiency (based on my understanding from heat geek videos), and
b) allow the bathroom towel rads in the upper floors be heated even if the upper floor is 'warm enough' according to the floor thermostat.
Currently each zone is wired to a a separate thermostat and I can see where these are connected in (2 wires from each thermostat). What i cant see from the samsung literature is how to switch control of these zones to the ground floor unit. Could i just disconnect Thermostat 2 and 3 and use jumper cables from Thermostat 1 to get things working as intended or is there a way to 'programme' this from the Samsung Controller?
Any assistance is appreciated in advance, I am struggling to make sense of the samsung/joule set up information to achieve this.
So I've found the answer to my own question. The joule control board is only wired in to the "Zone 1" of the gen6 controller. So zone 2 of the Samsung controller is irrelevant and however Zone 1 is set up will apply to all thermostat controls on the system.
In my case I am now trialling heating on pure weather compensation but with the thermostats acting as a high temp limit switch. So I have the thermostats on each level to 1 Deg above where I would like the room temperature and I will try playing with the water law settings (and maybe radiators) to dial it in.
To confirm the joule unit operates as such I contacted Samsung and confirmed that only the B22 live cable is connected between the Samsung board and the joule PCB. If there was B24 connected between the two it would control zone 2 on the Samsung controller
- 2,674 Topics
- 62.5 K Posts
- 157 Online
- 7,088 Members
Directory
RE: Several AC coupled batteries
@etchedpixels Absolutely, I built mine as I assumed it ...
By Batpred , 2 hours ago
RE: Heat pump design review please: 5 kW Vaillant aroTHERM Plus heat pump
@jamespa many thanks, definitely i will give the pre...
By ragtime27 , 2 hours ago
I take the point about the scarcity of helium gas - tho...
By Billsp44 , 3 hours ago
RE: Heat pump installation quotations
@jamespa I noticed that in the Heat Geek design consult...
By Batpred , 4 hours ago
BUS uplift to 9k for off grid installs. I can't establish if new builds are specifically excluded.
Hi.The BUS grant for new self builds is pretty straight...
By jimseng , 11 hours ago
Looking for installer in Somerset
Hi All I am looking for someone who can re quote for ...
Good point, I do expect the bonus of putting my energy ...
By Batpred , 13 hours ago
@bash, something we haven't touched on already relates ...
RE: GivEnergy inverter tripping due to over-voltage?
@transparent it might be interesting to note the early ...
By Tim441 , 16 hours ago
@jamespa these:
By AdamK , 22 hours ago
Vaillant arotherm plus 12kW. Installed March 2025. Ex...
By Harebell , 2 days ago
Last year we managed a net nil cost. Exceeding all my h...
By Tim441 , 2 days ago
RE: MCS 2.0 - Changes in January 2025
It strike's me that there's various improvements which ...
By Temperature_Gradient , 2 days ago
