Geiá sas kai kalós írthate @efficiencyseeker – please feel free to start a new thread to tell us more about your system and what kind of weather/temperatures you're dealing with in Greece.
Free UK shipping.
📗 Heat Pumps Explained
📘 From Zero to Heat Pump Hero
🛠️ Bodge Buster
New to heat pumps?
Posted by: @editorGeiá sas kai kalós írthate @efficiencyseeker – please feel free to start a new thread to tell us more about your system and what kind of weather/temperatures you're dealing with in Greece.
kalós sas vrika. Thanks for the warm welcome in Greek. I will start a new thread in order to provide more information and express my concerns.
Hello all 🙂
Just joined today, based in the Oxfordshire (UK) area. Had Solar for a little over a year, will share the details of my specific set up in the relevant thread.
@scoob welcome to the forums and look forward to seeing your numbers.
Free UK shipping.
🛠️ Bodge Buster
New to heat pumps?
Hi folks, very interested with the group subject matter. Background, after almost 50 years as a building services engineer i have been installing a huge range of M & E services into mostly commercial buildings. After retiring about 15 years ago i extended and refurbished a bungalo and installed everything "green" i could find at the time including an ASHP for heating and a separate ASHP for hot water supply. The kit we bought has performed ok but lacks the technical development that modern units offer so i am considering replacement. Looking forward to the new journey!
Hi I am systemsThinker01. We getting ready to install an ASHP in our new (self) build. Which in theory will be a passive house, so this should be a doddle. So we are talking to MCS certified installers and getting some odd things back. Although I would consider myself very technical I body-swerved thermodynamics after the compulsory bits at Uni and so am scrabbling to get my head around some of the more technical aspects but the commercial aspects are meat and drink to me and that is also confusing. Our house was designed with great U values everywhere and, according to our advisor, will meet the passive house criteria. Anyway a long way to go and hopefully reading more here will help me get my head around both the technical and commercial conundrums we are grappling with.
I think the challenge really comes down to learning who to trust and for that perhaps joining a crowd and getting it's wisdom should be valuable.
Thanks for reading.
@systemsthinker01 welcome to the forums. Please start a new thread relating to your new build when you’re ready and feel free to update us. I’d personally be very interested in hearing more about your house, insulation and how you’ll integrate the heating.
Free UK shipping.
🛠️ Bodge Buster
New to heat pumps?
Hi, I'm Stuart. I live by Loch Ewe in the Northwest Highlands of Scotland.
We have a Samsung Gen 6 8kW ASHP with a Joule Smartplumb Unvented Cylinder (DHW and buffer tank) and underfloor heating in a well insulated two bedroom bungalow built in 2020/21.
The system was installed by the plumber working on our new build and commissioned in 2022 by a third party engineer engaged by Joule. On handover following the commissioning, all the UFH room zones were set to maximum flow rate and the pumps were set to maximum and, lacking any experience or guidance, we started off using it like the oil fired heating in our old house.
Since we moved in we have been slowly gaining a better understanding of the system and how to improve its operation and performance, helped in no small part by the wealth of knowledge and experience available here on the Renewable Heating Hub.
I have spent nearly 40 years as an embedded software engineer in process control and communications systems and have recently started adding homebrewed temperature monitoring to the system plumbing to help with understanding the operation.
Things are certainly a lot better than they were initially but there are a few issues that are beyond my understanding so I hope that I can seek some guidance with these.
Thank you.
Posted by: @sjnOn handover following the commissioning, all the UFH room zones were set to maximum flow rate and the pumps were set to maximum and, lacking any experience or guidance, we started off using it like the oil fired heating in our old house.
You might wish to see what I wrote this morning about 'handover' on a topic about Bad Installation instigated by another new member of this forum.
Although the Building Regulations will be somewhat different on your side the border, I suspect there is similar wording regarding the need for site-specific documentation and training.
Posted by: @sjnI have spent nearly 40 years as an embedded software engineer in process control and communications systems and have recently started adding homebrewed temperature monitoring to the system plumbing to help with understanding the operation.
Sounds like fun - did some of that long ago now.
- 2,808 Topics
- 66.3 K Posts
- 3,653 Online
- 7,212 Members
@susannasaunders I use the A2A for shoulder periods ...
By Watcher , 6 hours ago
The interesting thing about the IBG: when I called them...
By davidnolan22 , 10 hours ago
Boiler Upgrade Scheme funding reduced by circa £750 million in 2026 budget
The funding for the BUS grant appears to have been subj...
By Rob of York , 17 hours ago
JamesPa The chart explains well how the heat curve an...
By trebor12345 , 20 hours ago
@burtis Thanks for posting this and Im so pleased you ...
RE: I need help with Ecodan ASHP
@f1p It turns out there have been a solar panel install...
By Andris , 2 days ago
@seaviews your installer would be right to say that the...
By GrahamF , 2 days ago
RE: Tradespeople on Their Phones: What’s Acceptable When They’re Working in Your Home?
Actually, that's a very important point. I've only ev...
These are likely inked. The basic explanation is tha...
RE: Electrical works for air to air heat pump
agree with above. I have not had extra costs added wh...
By Batpred , 3 days ago
Good to hear that you found a solution. Absolutely a...
RE: Are there any comparisons of DHW heat stores around?
@sarahemmm I have done things the opposite way round I ...
RE: How will removing the standing charge on gas bills benefit heat pumps?
The BUS grant funding for 2026/27 will run out at the c...
By Rob of York , 5 days ago
