Jokes and fun posts about heat pumps and renewables
My mate joined a startup company trying a new method for creating environmentally friendly power from farmyard manure. I thought he was working really hard trying to make the job work but in reality he was just going through the motions....
@toodles, I suspect you're getting a little confused. I think we might need to sit down and have a chat about the difference between the concepts of "best" and "worst"....
@majordennisbloodnok I’m given to understand that in modern parlance, Wicked is Good😳 Confused, Toodles.
You may well be right, @toodles. However, "modern" is definitely not an adjective to use on me.
@majordennisbloodnok Well, I can use such terms as HMRC and GovUK OneLogin think I will be born in 2047🫢. Somehow though, it seems to me that I am actually nearer 79 yoa!
According to today's Guardian article, ministers are reportedly preparing to raid the Boiler Upgrade Scheme to help fund Britain's defence spending.
Faced with this magnificent example of joined-up government, British heat pump manufacturers have responded with admirable ingenuity. I salute them!
Introducing the HEAT-SEEKER 7500. An 8kW air source heat pump boasting a 25km missile range, 4.2 SCOP, automatic threat detection and revolutionary weather and threat (WAT) compensation.
Better still, its now eligible under the newly proposed Ballistic Upgrade Scheme (BUS).
Simply bolt three surface-to-air missiles onto the unit and, according to the manufacturers, it can intercept an incoming enemy aircraft while maintaining a respectable 45C flow temperature.
Finally, a heating system the Treasury can justify funding.
NATO has been consulted and thankfully Britain's energy transition hasn't been cancelled. It's simply being rearmed!
It brings a new dimension to "air to air" heat pumps...
