What happens when the outside temperature exceeds the upper WC point?
@jamespa not found the hysteresis to be a problem yet. The house warms up a lot in the sunshine so it’s only back to our desired temperature by later in the evening, if at all (high thermal mass). We toggle between ‘active’ and expanded depending on the amount of sun.
I might turn the setting of outside temperature down further (present 17C) in summer to prevent any heating on a cool night. Happily fiddling right now!
The focus of this week’s podcast recording is on “Heat Pumps & What To Do in Warmer Weather” and I’ll pull questions from the the thread so far, but if anyone has other questions on this subject, please pop them below, DM or email me (editor@renewableheatinghub.co.uk)
@bontwoody asked your question at the start of this thread to the panel. An interesting reply from Graham Hendra.
@editor Thanks Mars. Interesting talk. I will just point out however I don’t actually run my heat pump at 40C when it’s 17C outside! Don’t know why I plucked that figure from the ether 😆
@bontwoody 😂 does your unit turn off when a specific OAT is hit?
@editor not via the WC curve but as @old_scientist mentioned the setting is in the FSV menu so I was able to set that to 19C rather than it’s default of 35 C OAT
1 month ago
Ecodan with FTC7 - True Weather Compensation
1 month ago
4 months ago
Warm weather and heat pumps.
10 months ago
12 months ago
- 299 Online
@skd I think your guess might well be right - unfortuna...
By Toodles , 4 minutes ago
By AndrewJ , 15 minutes ago
By Bash , 2 hours ago
By benson , 2 hours ago
By trebor12345 , 3 hours ago
By RobS , 4 hours ago
By Batpred , 6 hours ago
By GC61 , 7 hours ago
By cathodeRay , 11 hours ago
By JamesPa , 22 hours ago
By Batpred , 24 hours ago
By DavidB , 1 day ago
By Slartibartfast , 1 day ago
