Posted by: @rob-of-york£7.5k is a great deal of your own money to be spending on switching from gas to an A2W heat pump when your income is a pension of £13k a year. Particularly as it is unlikely that you'd see a reduction in running costs.
According to organisations that commissioned studies on this, like the energy saving trust, a2w heat pumps are cheaper to operate than a boiler.
I also agree that, for most households, if they get a battery and a suitable tou tariff, they will have a home warmed throughout the day and for a lower cost.
The gov is also shifting the burden if paying for gas to the ones that use it most. Hopefully the link from a boiler to ccs storage if resulting emissions will be made soon and then the pressure to switch due to bigger savings will increase..
Note annual maintenance for A2W is around £180 compared to around £90 for gas and around £80 for A2A.
Thanks! 👍 the A2W and A2A maintenance figures are worth knowing.
And yes, an A2W system just doesn't add up cost wise for me... I don't see a reality where that works financially. Even environmentally it's a hard sell. A modest A2A system for a few thousand could be beneficial without burning through too much money though and I think that's where I'm focusing on now. 🥴 It won't save money or at least, the ROI is laughable... 😂 but it will add some comfort in summer. Even if it's a really basic install.
Installed solar [7.44 kWp] and batteries [Sigenstor 3 x 8kWh] and 12 kW inverter in July 2025.
Posted by: @etchedpixelsThe saying on newbuild sites is "do your best, foam the rest"
... And that's being generous!
I'll tell you a little story about the build quality we have been witnessing from our house, which is literally across the road from the site offices of the property developer! How that came to be is another story in and of itself but I digress...
Next to the site office are two large dry mix cement towers. For most of the summer these have been non-operational. I don't know (nor really care) why. So the property builders decided to mix their mortar every morning in a dumper truck using a digger to slosh the mix around a bit while another monkey uses a hosepipe to chuck some water in the mix. I'm sure that the houses built with this mortar are of 1st rate quality! 👍🤡
I think that's a good choice.
Sensible cost effective options for A2A come down to:
(i) Single-split with an indoor unit in the upstairs landing - good for cooling, and some heating.
(ii) Single-split with an indoor unit in the living room - good for heating, and some cooling.
(iii) Multi-split with indoor units in the living room and the upstairs landing - a good mix for both heating and cooling.
Costs will be very roughly £2000 for (i) or (ii) and £4000 for (iii). Option (iii) would work best for both heating and cooling, but obviously at a cost.
Option (iii) is very similar to the set up we have, which was used to off load 6000kWh of heating from our gas CH last winter out of an annual consumption of around 14000kWh. I expect that it would be proportionately much more effective in a somewhat better insulated 80 sqm house than it is in a 140sqm one.
Reluctantly I think i agree with @rob-of-york given what you have told us, unless octopus will give you a very cheap quote for a2w. This is probably worth exploring particularly as they are promising an add on cooler next year. If they will quote low it would give you a simpler to operate properly integrated system so personally I would ask them to quote before finalising a decision.
With an 80 sq m well insulated house and 2A2W units, and provided you leave internal doors open, you may find you need gas only when it's at extreme coldest, to counter the colder walls which are furthest from the heat source.
Hi James, some good food for thought so thank you for that! It certainly doesn't hurt to get a quote from Octopus! We are not going to be in a position to act on any plans for a while yet anyway! Probably not until at least next summer at the earliest! 😟 which is a bummer because the 5% vat will have gone back on by then.
With an 80 sq m well insulated house and 2A2W units...
What do you consider an 2A2W system to comprise of please? Are you referring to a combo wet and dry system with two heat pumps (one for the water system and one for the air)? If so, I'm struggling to see how that would come in under £5k and how a wet system would dovetail with the current gas boiler combi system? Could you explain your thinking a little more please?
Sensible cost effective options for A2A come down to:(i) Single-split with an indoor unit in the upstairs landing - good for cooling, and some heating.(ii) Single-split with an indoor unit in the living room - good for heating, and some cooling.(iii) Multi-split with indoor units in the living room and the upstairs landing - a good mix for both heating and cooling.Costs will be very roughly £2000 for (i) or (ii) and £4000 for (iii).
Thanks for these ballpark figures @rob-of-york 😊 Always helps to know whether the train of thought is worth digging deeper into or just scrub it because it's not feasible in the first place. I think I'm leaning towards something like option 2 atm and that's probably going to be my focus around quotes for now. But this discussion is helpful in thrashing out what that plan might look like!
Posted by: @susannasaundersWhat do you consider an 2A2W system to comprise of please?
Sorry that was a mistype. I meant 2A2A ie a2a with 2 outlets.
The more I think about what you have said the more I think you should get a quote from octopus if only to rule it out. They may just come in with something attractive and well integrated for your case and it would be a pity to miss it if they do. Equally if they don't you will probably be more comfortable knowing you have tested it and they couldn't deliver.
Posted by: @jamespahe more I think about what you have said the more I think you should get a quote from octopus if only to rule it out. They may just come in with something attractive and well integrated for your case and it would be a pity to miss it if they do. Equally if they don't you will probably be more comfortable knowing you have tested it and they couldn't deliver.
Indeed! I'll float it their way and see what they come back with! 😊
And yes, a dual output A2A system is probably what we are most likely to be looking for... One in the lounge and one in main bedroom. A2A2 or A2A2O is probably a good abbreviation for this with O representing the number of outputs into the house that the split has.
@susannasaunders
…if you know any Octopus users don’t forget to use a referral on the off chance you proceed.
https://octopus.energy/smart-home-tech/lct-referral/
@watcher I'm already an Octopus customer and I'm on their Flux tariff atm...So I presume I can't get a discount from another Octopus customer referral code... 🙄
But a worthy thought otherwise! 😊
@susannasaunders
I would definitely get a friend to recommend in any case, on the off chance you get it. When I was getting my Cosy installed I told them I could get a referral and they said don’t worry and knocked it off my bill despite already being an electricity customer!
- 2,828 Topics
- 67.3 K Posts
- 2,281 Online
- 7,249 Members
