Meter Readings - What are theses meters telling me?
We can have a good guess @potatoman but it depends on where your installer has connected them into the system.
These are both power meters with the output in kWh.
They measure voltage & current at 50Hz AC which is converted to (kilo)watts, and are MID certified, which guarantees their accuracy for billing purposes (if required).
Every solar installation which has the capability to export to the grid must have an export meter fitted.
The left meter might therefore be showing the total exported to the grid since it was installed.
Ie this is "Power generated from solar panels" minus "power consumed within the house".
The right meter would appear to be recording the total power drawn by a heat-pump since it was fitted.
The KWH1M45 meter is specified for 5A - 45A current range.
Its output readings cannot be reset, and the figure is retained indefinitely when disconnected.
There is a pulse-output available on a pair of terminals.
That allows connection to other data-recording devices if required. That feature may not have been implemented.
When a heat-pump is installed, it is a requirement that the householder is provided with written diagrams and explanation of all the devices used in that system. You must also have been given instruction on how to operate the system and adjust/maintain it so as to use as little electricity as is reasonably possible [Building Regulations, Part-L].
It sounds to me like you don't have that information.
@transparent Hi thanks for your reply, you are correct in your assumtion, I have aboslutely no information of how to operate /maintain the installation.
We can provide more help if you want...
but you'll need to give us something to go on!
At this stage we don't yet know if you are the home-owner, nor whether it was you who had the system installed.
You might have just bought a house with the PV panels and heat-pump already present.
Equally, you could be renting the house, and it is the responsibility of a landlord to resolve such matters.
Please assume we're 'simple folk' and need everything explained to us.
In return we'll endeavour to provide solutions with as low a level of technical blurb as possible! 😀
@transparent Hi, I am the landlord of the property, we have had a 9 kw LG ASHP fitted under the ECO4 grant scheme.
I think its common that there is no instructions /hand over on these sort schemes
- 25 Forums
- 1,442 Topics
- 30.2 K Posts
- 43 Online
- 1,226 Members
@transparent my navitron 20 tube system was installed 2...
By David999 , 29 mins ago
RE: Effect of buffer tank or volumiser on heat pump system
Thank you very much for reminding me, Derek. My install...
By DavidAlgarve , 1 hour ago
Yes, it is one of those two who first alerted me to the...
By IvanOpinion , 16 hours ago
RE: EV charger installation question – I don't want to bury the cable
The fact that the MCB is rated 16A tells us what we nee...
By Transparent , 17 hours ago
RE: Are You Getting the Most Out of Your Renewable Energy?
Thanks, @editor. Ideally it’d be someone who would li...
By Majordennisbloodnok , 18 hours ago
Unless adequately controlled it could devour your bank ...
By Derek M , 19 hours ago
RE: ASHP Commissioning: What Questions Should I Ask the Installer?
@derek-m thanks - will look out for the point regarding...
By Declan90 , 2 days ago
RE: Noise problems with newly installed Samsung 8kW ASHP
@editor @kenbone Thanks, I would be very interested ...
By Elton , 2 days ago
This is all a bit too frequentist for my liking. The pr...
By scrchngwsl , 2 days ago
Relax with 4K drone footage of lawn mowing to a smooth Motown tune
Sending out some chilled weekend vibes to everyone. Lis...
RE: Incorrect Billing of Customers with a Smart Meter
The starting point of that discussion on Camelot-Forum ...
Share Your Experiences with Heat Pump Manufacturer Support
Have you ever reached out to your air source heat pump ...
RE: Is this a bad installation and is there something wrong with my Samsung heat pump?
@ant87 thanks for that.
By David999 , 3 days ago
I might change my mind again, but I'm currently unlikel...
By IvanOpinion , 3 days ago
RE: Samsung ASHP scheduling help
@elgreco69 worth reading the GitHub here as that will a...
By morh , 4 days ago
RE: ASHP sizing - value of Heat Transfer Coefficient
@toodles Thanks for the explanation I get it now as I h...
By Jancold , 4 days ago
RE: Questions about yearly heat pump maintenance
For the installer, I believe servicing and maintenance ...
@retrorich It is very worrying that any of this should ...
By Toodles , 4 days ago
RE: Spacing for roof fixing bolts ?
There is another consideration...but alas this doesn't ...
RE: Air source heat pumps and noise
Yes, but when they go wrong things get really sticky. D...
Heat Pump Humour
Latest Topics
By David999 15 hours ago
By heat-pump-newbie 7 days ago
By jamesw 7 days ago
By KoRWraith 1 week ago
Home energy storage & battery register
By Mars 1 week ago
