How to heat a bathroom when using an air to air heat pump?
One of the things concerning me about going air to air using mini splits is that it seems you can't use them in a bathroom. How do you keep the bathroom warm and towels dry in that case? Having an electric towel rail seems like a very energy inefficient solution.
Posted by: @faleshHaving an electric towel rail seems like a very energy inefficient solution.
I think you answered it yourself ! But they will be called infra red emitters or something similarly fancy…
I heard some people discussing using internal fan. But after anyone uses the toilet, the door is best kept shut for a while, while the extractor does its job … in my opinion
I have an electric towel rail. For me, it's the only solution.
Posted by: @faleshOne of the things concerning me about going air to air using mini splits is that it seems you can't use them in a bathroom. How do you keep the bathroom warm and towels dry in that case? Having an electric towel rail seems like a very energy inefficient solution.
Towel rails are next to useless for heating even with A2W, they just dont emit enough energy at low FTs.
With my A2W heat pump I do have a water based towel rail but mostly my bathroom is heated by transfer from the adjacent hallway (we leave the doors open except when its in use) and steam if someone runs a bath. If this weren't enough I would fit an electric towel rail on a timer.
Posted by: @jamespaTowel rails are next to useless for heating even with A2W, they just dont emit enough energy at low FTs.
We have large towel rails in our bathrooms and according to the heat loss surveys, they will be enough to keep our (fairly well insulated) bathrooms warm with our future A2W ASHP.
I agree though that for the same area and specially when they are chrome plated, towel rails are not very effective as radiators.
You can air/air a bathroom with a suitable ceiling or other unit. That said towel rails are the best way IMHO to solve the towel problem. Our bathroom is simply heated when the door is usually open with the general airflow from the heatpumps and that is fine, but boy do I regret not fitting an electric towel rail when we did so.
This is odd because I have had a quote for a Panasonic multi split system which included a cassette on the bathroom wall. Is that definitely not OK?
- 2,820 Topics
- 66.9 K Posts
- 2,431 Online
- 7,232 Members
By the same measure we should be insisting that all gas...
By Batpred , 2 hours ago
True but .. because the room is colder dt rad to room i...
By JamesPa , 2 hours ago
Got two or three heat pump quotes that don’t agree? Post them here.
One of the biggest sources of confusion I see on Renewa...
By Mars , 2 hours ago
I do not disagree with the concept of wanting to live a...
By Batpred , 3 hours ago
@singlespeed I am going to put a temperature sensor on ...
By fosterl2 , 4 hours ago
RE: Grant Aerona - Weather Compensation and Schedules
@taffonthetaff Yes, I have now gotten to the bottom of ...
By bontwoody , 5 hours ago
Occasionally our Grant R290 activates all three circuit...
By TaffontheTaff , 5 hours ago
@davec 47kwh for 3 days is very low, compared to what I...
By johnd , 7 hours ago
By JamesPa , 11 hours ago
By Mars , 12 hours ago
Do heat pump defrost cycles impair heat pump efficiency (COP values)?
The short answer is no, as far as I can see from data f...
By cathodeRay , 12 hours ago
By Judith , 1 day ago
