Posted by: @majordennisbloodnokIf I were to install 18 panels today, I'd get more efficient ones and 550W JA units are approximately £94 each. Pro-rating the generation, I'd expect approximately 382kWh from each of them over a year. If we use your model of importing cheap to fill up the battery and then using that for home and heat pump, that effectively means each of those 382kWh from a panel is worth 12p to me since that's my current export rate (and yes, I realise that could change, but so as I said could the import rate in your model), which works out at just under £46. That's a paypack of just a smidge over two years. Even taking into account the installation costs on top of that, we're still looking at a pretty reasonable break even point.
Ahem.. 🙂
A PV panel may be £94, so £750k for 4kwp, but the labour and other bits involved in getting PV installed changes the whole equation. Of course we all know that £4k for 4kwp installed would be excellent value including MCs etc..
And should we have plug in solar for £94 a panel (will we?), we would be on another league.
In any case, I still see payback vs that 3.5 p/kwh overnight rate, which I cannot see being beaten. Of course that can change and make the dream payback more aligned with normal investment.. 😉
Posted by: @marcexecPosted by: @bashI saw that 64kwh battery for £6000 and I wanted one immediately, even though I already have 45kwh of Fogstar batteries 😆
If you have a good (outdoor) location, a good few people re-use EV batteries with 400V capable inverters:
@marcexec, that's a very interesting project. Thanks for that.
Posted by: @batpredPosted by: @majordennisbloodnokIf I were to install 18 panels today, I'd get more efficient ones and 550W JA units are approximately £94 each. Pro-rating the generation, I'd expect approximately 382kWh from each of them over a year. If we use your model of importing cheap to fill up the battery and then using that for home and heat pump, that effectively means each of those 382kWh from a panel is worth 12p to me since that's my current export rate (and yes, I realise that could change, but so as I said could the import rate in your model), which works out at just under £46. That's a paypack of just a smidge over two years. Even taking into account the installation costs on top of that, we're still looking at a pretty reasonable break even point.
Ahem.. 🙂
Quite right. I was using a rough guesstimate of doubling the panel costs to get to a true installation cost, meaning a break even point of about 4 years which I would still expect most people to be comfortable with as an investment.
Posted by: @batpred...
And that, of course, is where the different viewpoints converge.
My total solar PV generation last year would, if taken instead from grid, have cost £162. I can't ignore the logic I put forward earlier but I also can't ignore your point of comparing break even with 3.5p/kWh. Nor do I think I should be discounting any of these points; the reality is that there are so many different ways of slicing and dicing this that the only practical way forward is, as @bash said, to do the numbers in one's own context and see what adds up best.
I will also happily admit I'm no accountant. Faced with two new figures that are better than my current situation, I see either a win or a big win. I can't bring myself to frame a sub-optimal gain as a form of loss because of the theoretical bigger gain I could've achieved. No doubt that colours my viewpoint in this whole discussion.
2 months ago
2 months ago
3 months ago
4 months ago
4 months ago
Currently viewing this topic 27 guests.
- 2,818 Topics
- 66.8 K Posts
- 3,355 Online
- 7,231 Members
By AndrewJ , 2 hours ago
By Mars , 4 hours ago
By EtchedPixels , 4 hours ago
By Judith , 8 hours ago
By JamesPa , 11 hours ago
By JamesPa , 13 hours ago
By Mars , 16 hours ago
By hml1827 , 1 day ago
By bobflux , 2 days ago
By EtchedPixels , 2 days ago
