Heat Pump SCOPs – The Truth Might Not Be What You Think
Posted by: @mike-hPosted by: @david-stanford
Aim for 15+ l/kW System Volume: This seems to be a reasonable rule of thumb for optimising efficiency.
Can you explain the mechanism for this effect? Could it just be coincidental rather than causal? System volume may prevent short cycling, but there are other ways of achieving that.
Sufficient system volume is also essential for ensuring there is enough energy in the system to perform effective defrost cycles (unless there is some form of additional heater present). Without sufficient volume, constant defrost cycles will quickly kill efficiency in colder weather, and leave the house cold.
Posted by: @dreiYou can even go as low as 40c flow temp, if you want a high SCOP, as long as your radiators are sized correctly and you use the correct desired room temp, nothing is impossible. I don't think you will find any radiators that can do 40c flow rate and room temp higher than 21c, unless going to silly 3 meters K3 rads or very very expensive multi chamber rads (£10k per radiator).
I think you’ll find it depends on the room heat loss. A low loss room can be heated by a much smaller difference between mean water temperature and required room temperatures with a moderate sized radiator. Of course we usually all want the smallest radiator that will work in the room. They’re not works of art despite the marketing of some designs.
Posted by: @david-stanfordAim for 15+ l/kW System Volume
Is that heat loss, or maximum output of the ASHP? Understand they should be fairly close in a good system, but both vary by outside temperatures.
- 2,523 Topics
- 58.7 K Posts
- 601 Online
- 6,802 Members
RE: A Single Voice for Heat Pumps, But Will It Finally Raise Industry Standards?
From what I’ve read, the Heat Pump Association UK is me...
By Jonatan , 27 minutes ago
Do that anyway, the main system controller that you use...
By JamesPa , 33 minutes ago
Pylontech US5000 stores about 4.3 kWh accounting for in...
By bobflux , 59 minutes ago
Hi @martinhook_uk @bobflux The installer is making g...
By Maximumdo , 2 hours ago
Hi all, Just an update on where we are with the "Consta...
By DEdwards , 2 hours ago
By giganto , 16 hours ago
By bobflux , 20 hours ago
By JamesPa , 21 hours ago
By Old_Scientist , 23 hours ago
By Ubert767 , 1 day ago
By benson , 1 day ago
By Jonatan , 1 day ago
By Batpred , 3 days ago
By RobS , 4 days ago
