First time wall mounting an ASHP
Hi all,
I have got the go ahead on a job to move their 5kW Samsung R32 from the floor, up onto a wall. I was planning to use these brackets (Pump House Type CBR2-L 2 Wall Bracket 540mm Long Arm 140Kg For Air Source Heat Pump), but as I mentioned I haven't done so before. Is there anything I should look out for, and what difference would this make on efficiency compared to your standard floor mount?
Thank you in advance
Im no expert, but if you are raising the heat pump, the air should be warmer than down on the ground and so it should improve its efficiency slightly.
@bontwoody Adam Chapman Heat Geek carried out an interesting experiment using mirrors (no smoke) to reflect sunlight back at the pump. Can’t remember which but it is a YouTube presentation of his. Regards, Toodles.
@toodles Ill have to look that one up 😁
what you need to do is everything you can to remove the vibration through the wall, these brackets are very good and allow you to adjust a rear foot to level the bracket tilt, I would add some aditional 100Kgs antivibe mounts as well, these can come with an 8mm M/M thread each side and would sit straight inside.Posted by: @renewables345Hi all,
Good luck
9 hours ago
2 days ago
2 days ago
Where has Watson gone?
3 days ago
2 months ago
- 2,396 Topics
- 54.3 K Posts
- 298 Online
- 6,077 Members
No need to create a new thread, @sheriff-fatman. You do...
By Majordennisbloodnok , 3 hours ago
RE: Power outages and storms: A surprisingly good DNO experience
Well done to Scottish Power for doing a good job. Well ...
Fair point. The highest frequency of defrosts I'd seen...
By Sheriff Fatman , 5 hours ago
RE: Heatpunk Floor plan issues
It's usually the complete opposite... seldom that Safar...
By Mars , 5 hours ago
@mike-patrick interesting update - thanks.I've been thr...
By Tim441 , 6 hours ago
I remember reading in some inverters. They mandate a se...
By Batpred , 7 hours ago
RE: Fan is clipping ice build up from the front of unit.
@majordennisbloodnok I’ll not go there thanks! Toodles.
By Toodles , 8 hours ago
@majordennisbloodnok Back in the 80’ or 90’ we had a te...
RE: Running my new Nibe ASHP efficiently
I'm new to the forum. Did you get a reply to this last ...
By Mike @ Camelot , 9 hours ago
@grantmethestrength MCS requirements for DHW capacity h...
By Toodles , 10 hours ago
Great to hear! I just figured this out a day or tw...
By anotherdaveuk , 11 hours ago
@adamk I'm observing my own system at low temperatures ...
By dr_dongle , 16 hours ago
RE: Free Ecoheat Heat Pump Install
@deltona Yes older houses are problematic like that, bu...
By bontwoody , 1 day ago
As I mentioned early on the cost of supplying and fitti...
Great point, one of the key ones in my chat with Octopu...
Let me point out that there are many Chinese suppliers ...
@majordennisbloodnok — The Two Ronnies Mastermind sketc...
Just realised that this image of the cylinder cupboard ...
Two thoughts: 1: Let's ask @david-s if Primary Pro in...
In the diagram below, I describe my understanding of th...
