Ecodan Legionella cycle - immersion heater problem
@clockworks Along with the Law, the MCS can be an ass with absobloominglutely no margin for pragmatism; we are two and used a 99 litre DHW cylinder without ever experiencing a shortage of hot water when we needed it. MCS guidelines (and validity for the BUS grant) required us to have a 210 litre tank as minimum for our 3.5 bedroomed semi. No space for any such animal so went for the Sunamp Thermino equivalent to 210 litre system at 25% of the volume - it sits in the base of our airing cupboard. We received the £5000 grant. Regards, Toodles.
Just to close this.
Finally had the installer back last week to fit an immersion thermostat with a higher rating.
As expected, no more rapid switching, immersion stays on and water gets up to temperature.
Thanks for letting us know @clockworks
I admire your optimism that the thread is now 'closed'.
It'll get re-opened at some point...
... when someone actually contracts legionnaires disease.
There will then be a lot of finger-pointing as to which organisation should take the blame.
- 2,779 Topics
- 65.5 K Posts
- 752 Online
- 7,185 Members
Hi. Wondering if someone can offer some basic advice on...
By mrkfm , 46 minutes ago
I did, indeed, go with the 12 KW Vaillant unit.  ...
By ian33a , 4 hours ago
Whenever I see the word modelled I am reminded of the t...
By cathodeRay , 6 hours ago
@olivierm welcome to the forums and finding the right i...
By Mars , 7 hours ago
I’ve had two calibration cycles in the last three month...
By Davesoa , 1 day ago
@editor That's a pity, but thank you for checking. I'l...
By ltron2 , 2 days ago
My fifth heat pump book, Heat Pumps Explained, is out n...
Just furkled Into the parameter menu. Found the master ...
By AgentGeorge , 2 days ago
It's interesting that Norway with a much colder climate...
By Rob of York , 2 days ago
Happy to add Scottish Power and the review 'dont touch ...
By Batpred , 4 days ago
By Toodles , 4 days ago
