Controlling Daikin ...
Controlling Daikin Altherma via P1P2 and Home Assistant
3 Users
1 Reactions
(@weoleyric)
Are there any fellow Daikin Altherma 3M owners who are using Home Assistant to control their heatpump?
I’ve installed a P1P2MQTT unit connected to HA to give me more control over our Daikin heat pump and to move away from the truly inflexible Daikin Onecta setup.
I’ve tried to set up the Daikin indoor unit so that it doesn’t interfere with HA control but I’m still finding some curious and frustrating results.
For instance, I wanted to set the hot water tank to only heat overnight during our Octopus Go cheap rate tariff, but I’m finding the Daikin hot water seems stubbornly stuck at 50c despite there being no schedule set on the indoor unit, and Eco DHW set to 30c and comfort DHW set to 35c.
if anyone else has tried to use HA to control their Daikin, I’d appreciate any tips for any aspect of the setup.
Our setup is
* Daikin Low Temperature Monobloc 4kW Heat Pump (EDLA04E2V3)
* Daikin Indoor Unit
* Daikin WLAN Adaptor (BRP069A78)
* Daikin 150L Hot Water Tank
* Solar iBoost+
76m² Semi-detached House in North East England
Nissan Leaf 110 kW N-Connecta, 2017 Hyundai IONIQ Premium SE PHEV
Podpoint EV charger
Daikin Altherma 3M ASHP (EDLA04E2V3)
Solar iBoost
SolaX X1 Hybrid Series inverter
2 × SolaX Triple Power 5.8 kWh Batteries
1 × EcoFlow Stream Ultra X 3.8 kWh, 1 × EcoFlow Stream Ultra 1.92 kWh, 2 × EcoFlow Stream AC 1.92 kWh batteries
12 × 365 W solar panels (roof), 1 × 380 W, 1 × 400 W, 1 × 200 W, 2 × 100 W solar panels (garden)
(@majordennisbloodnok)
I haven’t got a Daikin but I have been having some fun with MQTT on another thread. If anyone else can cover off the normal Daikin control stuff I’m happy to help fill in the MQTT and HA bits.
(@weoleyric)
@majordennisbloodnok Thank you!
My biggest head scratcher right now is I have the below automation (and similar) setup for overnight hot water, but the Daikin unit completely ignores it and heats DHW to 50c whenever it wants.
alias: Daikin DHW - Start Off Peak Heating (50C)
mode: single
triggers:
  - at: "00:30:00"
    trigger: time
conditions:
  - condition: time
    weekday:
      - mon
      - tue
      - wed
      - thu
      - fri
      - sat
actions:
  - target:
      entity_id: climate.bridge0_dhw_dhw_setpoint
    data:
      hvac_mode: heat
    action: climate.set_hvac_mode
  - delay: "00:00:02"
  - target:
    data:
      temperature: 52
    action: climate.set_temperature
  - data:
      message: "Off-peak start: DHW ON, target 52°C"
    action: logbook.log
Podpoint EV charger
Solar iBoost
So to clarify (and rephrase the problem into my own terms - bear of very little brain, here...), you're saying you can't find anywhere in the onboard controls of your heat pump where there's a schedule to heat your DHW and yet it's always staying at 50degC or reheating immediately it drops below that level. Is that correct? Or is it that your automation is trying to get the DHW to 52degC but the heat pump stops at a ceiling of 50degC?
(@weoleyric)
@majordennisbloodnok That’s correct. I can’t find anywhere in the heat pump controls that should be preventing Home Assistant from scheduling a 52c heat of the DHW.
Interestingly, in the installer settings on the Indoor Unit, there is a screen that shows 50c as you go into the setup. But it is greyed out and can’t be changed. That leads me to believe there may be a hidden Daikin setting I’m not aware of!
Podpoint EV charger
Solar iBoost
@weoleyric, apologies for the delay in response.
Given your last post, I'm still not clear whether you're having trouble finding where the DHW max temperature can be changed or whether you're having trouble finding how to change ANY of the DHW settings/schedule - in both cases, within the Daikin in-house controller. As a result, I'm trying to get hold of a forum member who's familiar with their way around the settings of your in-house controller so we can burrow into the settings and see what's going on.
Once we're clearer about what your heat pump is actually configured to do within its own settings, that's when I'd like to look at Home Assistant and see if you can do what you want by manually changing settings in HA. That'll prove that the MQTT communication is working properly. Once we've done that, that's when we can look at the automation and see if anything needs to be changed. First step, though, is to ignore anything outside the Daikin settings so we can simplify the problem.
@weoleyric Oh Dear, I don’t think I am going to be of much help here as my DHW is handled totally separately using a Sunamp Thermino ePC 210 unit.
Nevertheless, my heat pump is the 8 kW version of the Daikin EDLA08 monobloc with the MMI controller. Main control has been placed in the hands of the Homely Smart Controller though. @majordennisbloodnok wondered if I may be able to help - but I doubt I’ll be of any use to you here. Have you accessed the MMI settings that the installer uses? By setting up at installer level by using the code 5678 rather than the usual user level, you will have access to far more parameters. As I say, I don’t use the DHW settings on the MMI but you should be able to shuffle through the options for water heating and find the adjustments there. This may mean going down four or five level of submenu so take a packed lunch with you! Do you have the installer’s manual as this will show the route to you - though as manuals go, it is not the best example of clarity I’m afraid! Regards and Good Luck, Toodles.
On the contrary, @toodles, that’s a lot of help. I’d never have known about the code for the installer’s menu. Thanks.
