Advice needed after...
Advice needed after a successful "leftfield" experiment.....
5 Users
4 Reactions
(@pauli)
@chandykris
yup, my error, i was looking at old data
(@pauli)
@majordennisbloodnok
just checked, didn't realise this forum has been going on for so long, must be going through a recent surge in popularity seo wise 🙂
(@majordennisbloodnok)
No problem, @pauli. If you can find something useful, the forum has served its purpose.
(@chandykris)
@pauli Depending on whether you can get an EV tariff, I find that Octopus Go is a better option than Cosy for me. We were on Cosy in 2025 when we initially switched to Octopus in February after our heat pump installation. Prior to that we were on British Gas EV tariff  As we only had a 6.5 kWh battery, I preferred Cosy as we needed that 8 hours of off-peak energy and that too spread over the day in three slots. I was averaging 15p as I was able to avoid drawing from the grid during peak times. But, we switched to Go in April and then doubled the battery capacity to 13 kWh in May. So far this winter I am averaging 12p and now in March as there's more PV production, more like 9p.
Given that battery prices have dropped, it might work in the long run to get a bigger battery and be on Octopus Go or Intelligent Octopus Go than on Cosy. This would also reduce battery cycling and lead to longer battery life. Check out the Solar Optimiser tool on Tim and Kat's Green Walk website and model a few scenarios to help making the battery decision.
16 * 435 watts PV
13 kWh Growatt battery
1 EV - Mercedes EQB
6 kW Aira Heat Pump
Page 2 / 2
