@toodles, for company you should gone with "The Toodles".
Signed
Yup, signed.
Signed.
Signed
Thishas just been released by Government
MCS will become the sole certification scheme for
Boiler Upgrade Scheme;
• Warm Homes: Social Housing Fund;
• Warm Homes: Local Grant;
• Energy Company Obligation 4 (ECO4)
There is reference to a wider review of the consumer protection landscape and acknowledgement of concerns expressed about MCS, but this doesnt appear to have affected the outcome
Not sure where this leaves flexi-orb
The response says
"However, to mitigate the potential risks we are taking steps to increase oversight of MCS. This includes placing a DESNZ observer on the MCS Service Company decision-making board and putting in place a memorandum of understanding between the department and MCS. The MCS Consumer Protection Oversight Panel will also publish an annual report on their consumer protection performance. We will keep this arrangement under review, and consider if further measures are needed to ensure adequate oversight."
Yes, I’ve had a read of the Government response and their decision to go ahead with MCS as the sole certification scheme is despite them noting the concerns about monopolies and despite an overwhelming majority of respondents arguing against just using one scheme.
As I expected, the decision to go ahead ignored the input from the general public. If they’re going to ignore us, why ask us in the first place? Why not be honest and say “We do not value your opinion and won’t listen”?
Most likely because they have a legal duty to consult and to consider responses, but not to follow them.
Posted by: @majordennisbloodnokAs I expected, the decision to go ahead ignored the input from the general public. If they’re going to ignore us, why ask us in the first place? Why not be honest and say “We do not value your opinion and won’t listen”?
Oh, I understand they don’t HAVE to follow the comments but surely going against that weight of opinion makes it difficult to claim the exercise actually constituted “considering”.
I wonder if an FOI request would elicit the meeting minutes…
Posted by: @majordennisbloodnokI wonder if an FOI request would elicit the meeting minutes…
Thats a thought. There is a contact point given.
Having experienced making FOI requests on my LPA in relation to heat pumps there is a pretty wide ranging get out because these are handled under EIR not FOI. I suspect this get out will be used.
I must say I'm very disappointed by this decision. I have not yet read or processed the document. I'll reserve that as light bedtime reading in the next hour or so.
- 2,418 Topics
- 54.8 K Posts
- 289 Online
- 6,098 Members
RE: Ecodan Pump Issues… Circulation pump turns off when heat pump compressor turns off
@jamespa sorry James, yes larger surface area, messing ...
By ASHP-BOBBA , 41 minutes ago
In the Home Assistant firmware the data points...
By F1p , 48 minutes ago
RE: GSHP WOES! Midland based engineer recommendations?
@johnbroome if it is not the pressure in the expansion ...
By ASHP-BOBBA , 1 hour ago
RE: Installer Fitted 9kW Instead of 11kW Heat Pump and Changed MCS Paperwork - What do I do?
In recent cold weather th...
By JamesPa , 1 hour ago
So I hear the export MPAN that UKPN assigned should be ...
By Batpred , 4 hours ago
From what I read, the Solis has a very long list of err...
RE: Ideal HP290 14kW ASHP - how to optimise
Roughly this should cost you £250-£300 per peak month a...
By ASHP-BOBBA , 5 hours ago
RE: New Daikin 11kW Altherma 3M install - is it working as it should?
@toodles Thank you for your input. As the days have got...
By Synthbuilder , 9 hours ago
RE: Fan unit Making terrible noise HELP!!
@gutoffowc Oh no, sorry to hear that, are you in the Ke...
By ASHP-BOBBA , 11 hours ago
RE: Sunsynk Whole House Backup Issue
@sheriff-fatman - could you please re-post that in the ...
By Transparent , 11 hours ago
RE: Running my new Nibe ASHP efficiently
I didn't. I spent a while manually messing around with ...
By jamieheatpumpnew , 13 hours ago
RE: I’m glad the cold spell is over!
I comparison with the 65kWh used above yesterday was on...
By Judith , 13 hours ago
I should think so, I thought that pretty much universal...
By JamesPa , 14 hours ago
I'm also inclined to look into how a defrost is actuall...
By cathodeRay , 14 hours ago
MLCP (Multi-Layer Composite Pipe) for ASHP
@editor nope. The info you reported was sufficient for ...
By iotum , 1 day ago
RE: Experience - New Build / Complete New Heating System
@vincro I would be surprised if it is much above 5 to 6...
By ASHP-BOBBA , 1 day ago
RE: Post-Traumatic Heat Pump Stress Disorder
Yes bang on and maybe I can illustrate that by way of e...
