Tinkerer's corner
I'm assuming that your heat-pump control electronics has only a single port for an OAT?
Please check that there's not an adjacent one for an optional humidity sensor!
2: You don't have to plug in the OAT to that temp-sensor port.
You could just as easily have a microcontroller module to which you connect the existing OAT and a new humidity sensor.
Then you can freely play with creating a bespoke algorithm which outputs data in the format which the HP Control board accepts for the OAT port.
Posted by: @transparentI'm assuming that your heat-pump control electronics has only a single port for an OAT?
Please check that there's not an adjacent one for an optional humidity sensor!2: You don't have to plug in the OAT to that temp-sensor port.
Frankly, I've no idea about the physical setup but then I'm not too concerned either. My adjustment of the various offsets is done by Home Assistant and with that setup I can have humidity and temperature sensors coming out of my ears if I want. Indeed, I already do have a Shelly temperature and humidity sensor in the sitting room so I can calculate the dew point ready for next summer where I try out some mild cooling of UFH slab to slow down thermal gain in the inevitable heat wave.
My point is that I'm not worried about experimenting; I'm interested in opinions from anyone who already knows better than me (probably everyone) how best to run a heat pump in coldish but very humid weather.
Currently viewing this topic 2 users ( EtchedPixels, Transparent ) and 8 guests.
Recently viewed by users: Mars 10 minutes ago, Majordennisbloodnok 2 minutes ago.
- 2,817 Topics
- 2,296 Online
- 7,230 Members
Frankly, I've no idea about the physical setup but then...
By Majordennisbloodnok , 2 minutes ago
@editor I am not sure I am disagreeing with you, but yo...
By EtchedPixels , 6 minutes ago
@l8again those are really solid number. Please keep us ...
By Mars , 6 minutes ago
I’m not familiar with Samsung’s controls, but the long ...
By Mars , 1 hour ago
By Mars , 2 hours ago
By bobflux , 4 hours ago
By EtchedPixels , 17 hours ago
By Toodles , 23 hours ago
By EtchedPixels , 23 hours ago
By Chilli304 , 1 day ago
By JanHarley , 1 day ago
By bobflux , 2 days ago
