Geiá sas kai kalós írthate @efficiencyseeker – please feel free to start a new thread to tell us more about your system and what kind of weather/temperatures you're dealing with in Greece.
Posted by: @editorGeiá sas kai kalós írthate @efficiencyseeker – please feel free to start a new thread to tell us more about your system and what kind of weather/temperatures you're dealing with in Greece.
kalós sas vrika. Thanks for the warm welcome in Greek. I will start a new thread in order to provide more information and express my concerns.
Hello all 🙂
Just joined today, based in the Oxfordshire (UK) area. Had Solar for a little over a year, will share the details of my specific set up in the relevant thread.
@scoob welcome to the forums and look forward to seeing your numbers.
Hi folks, very interested with the group subject matter. Background, after almost 50 years as a building services engineer i have been installing a huge range of M & E services into mostly commercial buildings. After retiring about 15 years ago i extended and refurbished a bungalo and installed everything "green" i could find at the time including an ASHP for heating and a separate ASHP for hot water supply. The kit we bought has performed ok but lacks the technical development that modern units offer so i am considering replacement. Looking forward to the new journey!
Hi I am systemsThinker01. We getting ready to install an ASHP in our new (self) build. Which in theory will be a passive house, so this should be a doddle. So we are talking to MCS certified installers and getting some odd things back. Although I would consider myself very technical I body-swerved thermodynamics after the compulsory bits at Uni and so am scrabbling to get my head around some of the more technical aspects but the commercial aspects are meat and drink to me and that is also confusing. Our house was designed with great U values everywhere and, according to our advisor, will meet the passive house criteria. Anyway a long way to go and hopefully reading more here will help me get my head around both the technical and commercial conundrums we are grappling with.
I think the challenge really comes down to learning who to trust and for that perhaps joining a crowd and getting it's wisdom should be valuable.
Thanks for reading.
@systemsthinker01 welcome to the forums. Please start a new thread relating to your new build when you’re ready and feel free to update us. I’d personally be very interested in hearing more about your house, insulation and how you’ll integrate the heating.
Hi, I'm Stuart. I live by Loch Ewe in the Northwest Highlands of Scotland.
We have a Samsung Gen 6 8kW ASHP with a Joule Smartplumb Unvented Cylinder (DHW and buffer tank) and underfloor heating in a well insulated two bedroom bungalow built in 2020/21.
The system was installed by the plumber working on our new build and commissioned in 2022 by a third party engineer engaged by Joule. On handover following the commissioning, all the UFH room zones were set to maximum flow rate and the pumps were set to maximum and, lacking any experience or guidance, we started off using it like the oil fired heating in our old house.
Since we moved in we have been slowly gaining a better understanding of the system and how to improve its operation and performance, helped in no small part by the wealth of knowledge and experience available here on the Renewable Heating Hub.
I have spent nearly 40 years as an embedded software engineer in process control and communications systems and have recently started adding homebrewed temperature monitoring to the system plumbing to help with understanding the operation.
Things are certainly a lot better than they were initially but there are a few issues that are beyond my understanding so I hope that I can seek some guidance with these.
Thank you.
Posted by: @sjnOn handover following the commissioning, all the UFH room zones were set to maximum flow rate and the pumps were set to maximum and, lacking any experience or guidance, we started off using it like the oil fired heating in our old house.
You might wish to see what I wrote this morning about 'handover' on a topic about Bad Installation instigated by another new member of this forum.
Although the Building Regulations will be somewhat different on your side the border, I suspect there is similar wording regarding the need for site-specific documentation and training.
Posted by: @sjnI have spent nearly 40 years as an embedded software engineer in process control and communications systems and have recently started adding homebrewed temperature monitoring to the system plumbing to help with understanding the operation.
Sounds like fun - did some of that long ago now.
- 2,342 Topics
- 53 K Posts
- 238 Online
- 6,000 Members
RE: Speedcomfort radiator fans
@editor why have you removed the YT links?
By Deltona , 6 minutes ago
@editor - it's possible that OVO are withdrawing their ...
By Transparent , 10 minutes ago
@batpred Which BMS do you mean? You say you...
By Bash , 19 minutes ago
@andrewj I had to have a recalc done after my survey in...
By HarrisonC , 55 minutes ago
RE: OVO ending its Heat Pump Plus Tariff
Likewise! I only switched to Ovo 2 months ago specifica...
By Tallmarc , 1 hour ago
I agree! Even more so if we get an answer! But the chal...
By cathodeRay , 2 hours ago
Thanks for the tips. The engineer booked to do my (ne...
By 2StacksTerry , 4 hours ago
This has been delayed from what I believe to be this ye...
By dgclimatecontrol , 5 hours ago
this is why I provided current flow temperatures in the...
By ksim , 6 hours ago
RE: Why Millions of UK Homes Struggle With Heat Pumps
There's many homes that would be quite a disruption for...
By dgclimatecontrol , 6 hours ago
RE: Ecodan unable to hit legionella target temp - what's the consensus?
@rhh2348 ...maybe this option is what you want? Alter...
By benson , 6 hours ago
RE: Free Ecoheat Heat Pump Install
@old_scientist This does make the unit smaller as the b...
@old_scientist hiya mate, did you ever get to the botto...
By 9jwr9 , 12 hours ago
RE: Advice on internal circulation pump noise
Welcome and I am sorry you are having this problem. &...
By JamesPa , 20 hours ago
RE: Heat Pump Heats the House… But It’s Not Cosy. Emitter Changes or System Tweak?
@alastair, in short, no, increasing emitter capacity wo...
By Mars , 23 hours ago
@majordennisbloodnok I think the HPDHD diagnosis may be...
By Sheriff Fatman , 1 day ago
RE: External pipework insulation
I don't think we can tell from a photo whether your exi...
By Transparent , 1 day ago
RE: Controlling Daikin Altherma via P1P2 and Home Assistant
@majordennisbloodnok That’s correct. I can’t find anywh...
By weoleyric , 1 day ago
