Is my Samsung heat pump working too well?
Thank you for your understanding. I was awake in the night so went over at 3am to see what it was doing, and woke up grumpy 😊
The temperature in the house was better, but it was only 6° outside and I had some windows open. The outside unit was running when I arrived, but according to the controller the 'water tank sterilisation' cycle was running, so it could have coincidentally have been that.
I lowered the flow temp slightly again and on a whim reduced the WL2 settings to the same, although I sure it's set on WL1
Just went there now and it's far more comfortable (though windows are still open). I also played around with the settings but this time touch testing the pipes either side of the diverter valve (rather than rads). Everything seemed to be working as I would expect.
So I think the issue might be that it's operating as it should, but wildly overestimating expected heat loss. Then the sun comes in the south facing windows and makes things worse.
I guess I need a room stat or s
Oops... hit reply
I need some way to compensate for this better. I've also now reduced the controller setting by the maximum -5.
On which...
What does 'Outing mode' actually do? The instructions vaguely say "heating can operate at low temperature " but that's all. If this is on, does the domestic hot water still heat as normal?
Posted by: @pooneilSo I think the issue might be that it's operating as it should, but wildly overestimating expected heat loss. Then the sun comes in the south facing windows and makes things worse.
Good to hear this, sensible to set the WL2 curve the same as WL1 for now also, avoids any ambiguity. Sun and south facing windows can be a mixed bag. I have them and at this time of year the house overheats by 2-3 degrees during the day and then cools back down rapidly at night. That was true also with gas, although the ASHP seems to perform better than the gas did. In the height of summer I close the curtains!
Posted by: @pooneilI guess I need a room stat
The controller has a built in room stat. It also has the ability (I think) to raise or lower the flow temperature by a few degrees without changing the WC curve. Depending on how you set it up one or other of these is accessible in 'user' as opposed to 'installer' mode. Although the Samsung controller isnt as user friendly as some, it still has the essentials, it beggars belief that installers put it in a cupboard unless they are also installing homely.
If you buy a separate room stat do not buy a clever one. Some 'clever' ones attempt to pulse width modulate the boiler as they approach the set temperature. Thats about the worst possible thing to do with an ashp. You want a dumb one or the one in the controller.
Personally id go for the latter. If you get a stat you either have to wire it up, in which case you may as well move the controller and wire that, or you will get a wireless one which isn't necessarily reliable. That said I dont know the layout of the house so it maybe that wireless is the only realistic option at this stage.
I believe the water flow adjustment as user that you mentioned is what I've now reduced by the maximum of -5
To be fair to my installer, it was totally my fault that I didn't provide a cable for the controller. My electrician asked at 1st fix, I said I'd check, then I forgot, and by the time we remembered the house was plastered.
Any idea about the "Outing mode"?
I assume it does the same as reducing water flow as mentioned above, but with one quick button. I don't want to advise the tenant that this is an option if it turns dhw off as well.
@pooneil Apparently you can set up a different water law for the outing mode. see this thread:
If thats the case and you can find what it is set to then that might give you the settings you are looking for as you said the temperature was comfortable when using it.
I might have missed this earlier in the topic, but what temperature is the controller reading inside the cupboard with everything else? Is it desperately trying to heat up the part of the house that heats up the slowest?
Hi all
Thought I should give you an update on this after all your help.
In short, we installed Homely and the tenants are very happy. They set their desired temperature on the app and haven't touched it since. I'm told the heating is hardly ever coming on now, even when it's cold at night, because the Homely thermostat is registering the actual indoor temperature.
From my experience, without this installed, the system was not fit for purpose.
Thanks
@pooneil thanks for the feedback. Good to know it worked out in the end and Homely functions well.
Posted by: @pooneilFrom my experience, without this installed, the system was not fit for purpose.
Thats in itself is interesting. I have a Vaillant heat pump the interface to which (once WC is basically set up) is (IMHO) suitable for non techy people/tenants/visitors. It has a a simple dial to turn temperature up or down which, behind the scenes, actually changes the WC curve. The scheduler does likewise. I know at least a couple of other European manufacturers also adopt the same approach. This works even if there is zero 'room influence'.
It seems that some (principally far eastern) heat pump manufacturers haven't yet taken it to the level that some of the (principally European) manufacturers have. I suspect this is because the European manufacturers have had to deal with WC on gas boilers for two decades - its been compulsory for a while in some more enlightened EU countries - and so have been forced to invent a usable UI.
- 385 Online
By Bash , 2 minutes ago
By Bash , 58 minutes ago
By benson , 1 hour ago
By RobS , 1 hour ago
By trebor12345 , 2 hours ago
By L8Again , 2 hours ago
By cathodeRay , 2 hours ago
By Batpred , 3 hours ago
By AndrewJ , 3 hours ago
By GC61 , 10 hours ago
By DavidB , 1 day ago
By Slartibartfast , 1 day ago
