Samsung Gen 7 16kW ...
2 Users
3 Reactions
(@antonical)
Looking for some assistance to get modbus monitoring working on our Samsung Gen 7 unit. With the aim of putting some sensors in our Home Assistant setup.
I can communicate with the modbus card but find the data and mapping it seem to be a real challenge and the hope of producing a HA sensor showing the realtime COP a pipe dream as I cannot reliably get the LWT RWT and Flow rate. I already have the realtime power from a Shelly Pro em50. But can't get the flow rate.
I have followed the work Glyn did that fed into eamonhub, but it doesn't seem to work with the Gen 7. https://community.openenergymonitor.org/t/emonhub-support-for-samsung-heatpump-monitoring-via-modbus/21154/
Can anyone assist with this? I am sure if we can get it working it will help others looking to do some HA integration/automation.
Any help appreciated.
Cheers
6.5kWp of Solar G98 3.6kW inverter 32kWh battery. Samsung Gen 7 16kW Integrated Unit Newark Cylinders 'Heat Geek' Custom SuperTank and 50Ltr Volumiser Tank.
(@majordennisbloodnok)
@antonical, this is definitely shaping up to be a sleeves-rolled-up exercise. I thought there’d be a HACS project already for something like this but it seems not.
How comfortable are you with HA already? I want to ask if you’ve explored the modbus HA integration but don’t know if that’s a dumb thing to ask, if you’re thinking “what modbus integration or if you’re somewhere in between. I’d also be interested if you’re currently connecting via a serial connection or via an RS485 to ethernet adapter.
(@antonical)
@majordennisbloodnok This is what I built today.
It's a work in progress but a good start.
Cheers
(@antonical)
The setup for this is a Samsung Modbus card. Connected via samsung specification wiring back into the house into a Waveshare RS485 to ETH (B) POE adaptor. This is setup as a server with the following settings. Port 502, 9600, 8, 1, Even. Alow multiple connections.
Cheers
