Rodents! A word of ...
9 Users
13 Reactions
(@tim441)
Prominent Member Contributor
just thinking about how a mouse got in the hole on the bottom of heat pump. I'm guessing that leaves building up on the drip tray helped give it a platform to climb on? Something to keep cleared.
LG Therma V 16kw ASHP
Underfloor heating + Rads
8kw pv solar
3 x 8.2kw GivEnergy batteries
Manual changeover EPS
MG4 EV
@tim441 As an annual event, I used to record the Christmas Service for a local Private School. One Christmas week, I arrived at the chapel and started to set up all the audio equipment and then plugged into the main …. no power! Upon investigation we found the fried culprit with its’ teeth still engaged with the lead sheathing of the mains wiring. (The chapel rarely had need of electrical power as they still used candles for all ceremonies; power was run from a nearby Master’s House and I was set up in time for the proceedings.) Regards, Toodles.
Wasps caused frequent tripping of my lighting circuit a few years ago.  A fair amount of ceiling was removed to find a joint block in which several had met their maker.
(@lucia)
@tim441 I will need to give some thought to protect the hole with mesh.... perhaps expanding mesh used by builders. Either galvanised or stainless
Just an fyi but steel wool washing up pads are very effective at keeping those critturs out.  This is tried and tested. I buy multi packs and pull them apart.  🐭😁
@lucia One look at that protection and the rodents will make a clean getaway 😉.
Page 2 / 2
