Our 10 year old Grant heat pump failed
Posted by: @mike-patrick£280 it was better to consider a new ASHP given its age!
Well thats clearly nonsense. If a £280 pump failed in a boiler you would replace the pump, as you would in an ASHP.
Posted by: @bobfluxThese systems should work fine without requiring the user to become a part time heat engineer and plumber. Unfortunately, visits from the "tech wizards" are damn expensive, and one tends to lead to another, then another... at some point it becomes profitable to invest the time to learn just enough to debug it on your own.
You can diagnose most of the issues yourself if you have a service manual, access to installer settings, and a forum with people willing to help.
Sadly that's true of many things these days. The skill of fault diagnosis has become increasingly rare as things have become less repairable. Cars are just as bad, take a car with a fault into the workshop and basically most of the fitters (I will not dignify when with the title engineer, because mostly they aren't) will plug it into the computer and change parts until the problem goes away, charging the customer each time, without a shred of understanding.
Posted by: @mike-patrickOur ASHP has a history and about 5 years ago we did have a new PCB, which cost then about £800.
I had to have a new PCB on a boiler and it cost £500, its probably the most expensive part because its model specific whereas most other parts are generic. The boiler in question was very simple, I suspect a more modern boiler would have been more.
I think @bobflux has summed up the way to approach this in his post above here
- 2,523 Topics
- 58.7 K Posts
- 442 Online
- 6,802 Members
@newby Sorry to hear about your problems C...
By JamesPa , 39 minutes ago
I was replying to a post with no content relating to my...
By RobS , 2 hours ago
Well thats clearly nonsense. If a £280 pump failed in ...
By JamesPa , 2 hours ago
RE: Daikin Altherma 3 11 kW Heat Pump – More Efficient But Not Necessarily Cheaper To Run?
The fact that when the demand (ie house loss) is less t...
@toodles Quite properly, I evict myself from the house ...
By Papahuhu , 5 hours ago
It's possible to estimate the minimum power from the in...
By bobflux , 12 hours ago
@editor I am still very confused by it all. Stage 1 ...
By Dwynwen , 12 hours ago
Interpreting MelPump data / cycling?
Hello All. Our heat pump was installed in 2022 and I'...
By Boodgie , 13 hours ago
@editor Daikin’s usual reply is ‘Ask your installer’ - ...
By Toodles , 15 hours ago
This looks like a practical solution 👍
By bobflux , 1 day ago
Your installer may well be right. If the WC curve isnt...
3 X Pylontech US2000 Plus @ 2.4 Kw each = 7.2 Kw SoFa...
By vzm56n , 1 day ago
Horizontal Hot Water Cylinders for ASHP with Energy Efficiency Rating 'A'
I looking to Have an ASHP installed in the near future....
RE: Noisy Grant Aerona 3 13kW ASHP question
Here's a LibreOffice spreadsheet. I put the formula f...
I assumed you were joking here. Hence my joke about ...
Photos of cylinder cupboard and UFH manifold would be u...
Something big is coming to Renewable Heating Hub! Ove...
RE: A Single Voice for Heat Pumps, But Will It Finally Raise Industry Standards?
From what I’ve read, the Heat Pump Association UK is me...
By Jonatan , 2 days ago
Pylontech US5000 stores about 4.3 kWh accounting for in...
By bobflux , 2 days ago
Hi all, Just an update on where we are with the "Consta...
By DEdwards , 2 days ago
By giganto , 3 days ago
By bobflux , 3 days ago
