This particular example is one of the worst I have seen here. Uninsulated buried primaries!, uninsulated pipework around the cylinder, system separation, oversized heat pump, undersized radiators and doubtless some things we don't know about because they are masked.Â
The plumber who 'installed' this should be struck off! It's almost like they designed it not to work, but I doubt they were that competent. The lack of insulation would be equally bad if this were a boiler installation (worse in the case if the dhw tank, because it would be heated to a higher temperature), how were they ever let near this job. It makes one wonder about the rest of the plumbing.
3 months ago
3 months ago
Ecodan 11.2kw Wireless thermostat drop outs
4 months ago
Mitsubishi Ecodan System Pressure Changes - An Issue or Expected ?
4 months ago
Transforming a Derbyshire Property into an Energy-Efficient Haven
5 months ago
- 2,118 Topics
- 46.6 K Posts
- 77 Online
- 4,523 Members
By Transparent , 9 minutes ago
By JamesPa , 4 hours ago
By TRBob , 4 hours ago
I may need to adopt this technique lol!
By Grantmethestrength , 5 hours ago
By JamesPa , 6 hours ago
By Toodles , 20 hours ago
By normpang , 2 days ago
By ASHP-BOBBA , 3 days ago
By Burtis , 7 days ago
By JamesPa , 7 days ago
By Lucia , 1 week ago
