[Sticky] Home energy storage & battery register
Posted by: @arundalepSolaredge Energy Bank DC coupled
10 kWh (9.7 usable).
Nissan Leaf 30 kWh with Indra V2G charger (hacked of course) giving a usable 21 kWh of battery storage.
Both are integrated with our Home Assistant based HEMS to allow everything to play nicely together.
I love that!
Unfortunately there doesn't appear currently to be a V2G available on the market (the ones out there are, I believe, all associated with trials). Once one comes out I'm sorely tempted to replace our 'second' car (a petrol fiesta) with an ageing leaf (I dont yet have a battery, other than the one in our Kia e-niro which, sadly, isnt bidirectional).
Tesla PW3 (13.5kW) and Gateway for full home backup.
@old_scientist 😊 Toodles
Battery 1 x 5kWh Growatt, would consider a second when prices soften
I don't have a Hybrid Inverter ( which has the H, SPH)
Growatt PV Grid Inverter MIN 5000TL-X
SPA 3000TL
Growatt AC Coupled Inverter SPA 3000TL BL
supplied and fitted by my home solar who I’d recommend getting a quote from.
2 days uninterruptible power supply (at the moment) with Solis 8kW and 16kWh lifepo4
16kWh Seplos Fogstar battery; 8kW Solis S6-EH1P8K-L-PLUS hybrid inverter; Ohme Home Pro EV charger; 100Amp head, HA lab on mini PC
I have Solax X1-AC with 5.8kWh. Last month we installed Solis 3P Hybrid with a fabulous Dyness HV stack. next project will probably be single phase Solis with either another Dyness stackable or the Fogstar.
Posted by: @williamp@batpred I'm looking at Fogstar batteries with Solis as an alternative to Dyness, how do you find them?
Most of my findings on batteries are in the thread that this link points to. Regarding the inverter, the Solis hybrid exceeded my expectations.
Now the proud owner of:
4.1Kw peak Aiko Neostar solar panels (south facing)
GivEnergy Gen3 hybrid 10Kw inverter
GivEnergy 34Kwh HV stackable batteries
Bivalent system containing:
4.1Kw Solar Panel Array
- 2,378 Topics
- 53.9 K Posts
- 176 Online
- 6,060 Members
No chance! Largely, hence my suggestion to do some...
By JamesPa , 5 hours ago
As it turns out this is correct! All I needed to do was...
By benson , 6 hours ago
Here is an update of the setback we operate on our syst...
By SUNandAIR , 8 hours ago
RE: Grant ASHP 17.5 kw. weather curve
@chinkoa Sorry there are two separate thoug...
By JamesPa , 9 hours ago
@transparent As easy as putting sparklers in champag...
By Papahuhu , 9 hours ago
@f1p Looks good, and will likely be something I use whe...
RE: Cascade 2x Grant Areona 10kw ASHP - Ongoing setup issues
Either complete Bow Locks or at best a marginal effect....
By JamesPa , 15 hours ago
Hi all I’m looking to get some insight on what others...
By Renewables345 , 15 hours ago
RE: The Great British Heat Pump Owner Persona Survey: Let's Build Our Archetype!
@mosibi, go on then, complete the survey. Let's get the...
By Mars , 15 hours ago
RE: Water Hammer After Heat Pump Install
@jaynieq I wish you luck with this one. I think the ma...
By JamesPa , 17 hours ago
RE: Optimum new build house design for Heat Pump
From first principles I would say: Definitel...
As good a place as any to drop this video:/p>
@transparent D'Oh - I did look before I posted but I mi...
By dr_dongle , 2 days ago
Compatibility with Samsung AE080RXYDEH
I am new to all this. We have a SamsungAE080RXYDEH that...
By John999 , 2 days ago
@batpred Maybe you should buy your additional batter...
By Bash , 2 days ago
RE: Data Accuracy Problem: Daikin 8kW Heat Pump's Onecta App vs MMI Power Consumption
@nursethescreens Yes, comfort and happiness of the fami...
Thanks folks. I had tried googling an ethernet lab adap...
By z8lccda , 2 days ago
RE: Changing from 4-port buffer to volumizer
@toodles I'm not concerned that the behaviour is not no...
By Andy1618 , 2 days ago
I agree, and I think there are two things in play here....
