i believe the new rule is the ultra high fixed will be able to leave with no cost and rejoin at the fixed tariff that is coming in.also those on a higher fixed but not ultra high will be dropped down to the new fix.
Whilst I try not to be political, has anyone noticed that our new Chancellor would appear to have tanked the pound sterling by 3.6% against the US dollar, in his obvious desire to make the rich, richer.
Since gas and oil are priced in US dollars, I suspect it will not be too good for the not so rich.
I was sent this petition link this morning (a tad late) pertaining to OFGEM’s price cap: https://chng.it/zHjftSzr47
OVO Power Move
https://www.ovoenergy.com/blog/ovo-news-power-move
OVO will contact customers directly who meet the criteria
Demand Flexibility Service DFS
It follows an earlier large scale Octopus trail
https://www.nationalgrideso.com/industry-information/balancing-services/demand-flexibility
Although the government subsidised price cap doesn't help me (I fixed a 2 year price in February at slightly below the new cap - I'm electric only) I've just noticed that the differential between the capped gas and capped electricity prices has narrowed to a factor of about 3.5. Last time I looked (before Ukraine invasion) electricity was about 5x more expensive than gas, per kWh.
I wonder if this is just happenstance or deliberate policy? If the latter and it is to be maintained then it improves the case for ASHPs, bringing the price difference very much more within their achievable efficiency. One more dis-incentive removed. Just need the EPC rating system to change now.
Mike
@mike-patrick I don't think it's a coincidence. When you add the fact that even a new gas boiler is only up to 90% efficient (and old ones are a lot less) then the differential is less. Mains gas was far too cheap and there was no real cost pressure to use less.
Posted by: @kev-m@mike-patrick I don't think it's a coincidence. When you add the fact that even a new gas boiler is only up to 90% efficient (and old ones are a lot less) then the differential is less. Mains gas was far too cheap and there was no real cost pressure to use less.
There is now. ☹️
- 2,265 Topics
- 50.6 K Posts
- 393 Online
- 5,924 Members
Is the distance between those new farms and where the e...
By Batpred , 11 minutes ago
@jamespa hopefully after the rad balancing it will perf...
By AdamK , 12 minutes ago
@mosibi yes I am interested in potentally evolving my s...
By benson , 2 hours ago
RE: UFH downstairs and radiators upstairs balancing question
@davidnolan22 Hi, ok first of all it very hard to truly...
By ASHP-BOBBA , 3 hours ago
RE: Grant 13kW Aerona3 - issues getting zones to temp
Installers coming tomorrow. One has messaged messaging ...
By Crimson , 4 hours ago
11.2kW Ecodan Manufacturer: Misubishi Model: PUZ-WM...
By DRB01 , 4 hours ago
RE: Homely asking about Solar Panels.
@majordennisbloodnok I will report back with any develo...
By Toodles , 6 hours ago
RE: Mediation with RECC, what's your experience?
@editor Thank you, I really appreciate it! I've made ...
By TreeWizard , 8 hours ago
RE: Installer Fitted 9kW Instead of 11kW Heat Pump and Changed MCS Paperwork - What do I do?
Are you able to post a photo of that 180-litre cylinder...
By Transparent , 10 hours ago
Agreed. It doesn't take all that much maintenance to ke...
By Majordennisbloodnok , 12 hours ago
RE: Oil Boiler & Heat Pump Hybrid System
OK. Got it. As a fellow rural West Country resident, ...
By Transparent , 14 hours ago
RE: My DIY Heat Pump installation
@pollar-bear Top job, I installed my own too and even t...
By bontwoody , 15 hours ago
Not sure how you got that information, @batpred. As of ...
Ok so that seems to be the key point namely only mcs ca...
RE: One flow valve appears to be duff
You might want to consider the following common faults:...
By IaAck , 2 days ago
RE: When to use Octopus Intelligent Go tariff with my heat pump and battery
We are on the Intelligent Octopus Go tariff. We instal...
By GrahamF , 2 days ago
RE: New build installation query
@paullacey While the others wait for more info do you m...
By ASHP-BOBBA , 2 days ago
