[Sticky] Air-to-Air Heat Pumps & Air Conditioning: UK Heating and Cooling Q&A
Welcome to our dedicated thread for air-to-air heat pumps and air conditioning in UK homes, covering both heating and cooling.
Whether you’re considering your first system, comparing installation quotes or already have one and need a little help, post your general questions here. We’re interested in the everyday experience as much as the equipment like how comfortably it heats or cools your home, what it costs to run and whether you’d make the same choices again.
If you want more focused replies to your particular project please start a new deviated thread instead. Give us a little background about your home and what you’re hoping to achieve, along with the make and model if you already have a system or quotation, so members can offer more useful replies.
And if you’ve been living with air-to-air for a while, please share what you’ve learned here. Your experience could help someone else make a much more confident decision.
To kick things off, here’s our Homeowners’ Q&A podcast with Simon Baseden, covering the practicalities of using air-to-air for heating and cooling, which homes it suits and some of the less obvious considerations around hot water and the BUS grant.
Have a watch and let us know what you think.
Our latest Homeowners’ Q&A episode has just dropped, where I was once again joined by Simon Baseden (@ashp-bobba) to compare air-to-air and air-to-water heat pumps for UK homes.
We look beyond the headline installation prices to ask whether A2A can genuinely replace a boiler and heat the whole house (including bedrooms with the doors closed) while exploring heat loss, sizing, cooling and the design mistakes homeowners should watch out for.
Thanks for that, quite interesting.
I liked the bit about judging the quality of installers by their vans. I was quite surprised when one of my neighbours beat me to getting a heat pump. The people who installed their A2W system turned up in a couple of beat up vans.
Of course I don't know that it's a bad installation. Still I'm a little concerned that the pipes into the house (primaries?) are only 22mm. The outdoor unit looks enormous but I checked and it's a US brand TCL which use the same case for anything from 6-16kW. So it may not be over sized.
I haven't quizzed them about the details of their system. All I know is it was in response to a leaflet through the door offering to replace their boiler 'for nowt' i.e. all covered by the BUS grant. Well it is Yorkshire...
The only constructive thing I can think to do is see if they've looked into suitable tariffs. Also maybe ask how it's configured, flow temperature, weather compensation.. etc.. Not my problem but they're nice people.
Hope no one minds a slight digression on this post. i have been researching air to water systems for a while, but my wife has thrown a spanner in the works by suggesting air to air, as she would like cooling in the bedroom. Neither of is particularly healthy so cooking in summer cold potentially provide significant health and lifestyle benefits. At present i am leaning towards the Daikin Multi + system with four splits of 3.5, 2.5, 2.5, 2,5 with the 230l water tank. finding anyone who has the system already or an installer who has installed the tank with the multi is proving difficult in the rural north. Has anyone any experience of this, can offer advice, ideas on efficiency beyond the simple figures on the Daikin website. Any info or practical experience at all would be greatly appreciated. i am even considering a hybrid approach where we still keep the gas boiler as back up, with a bypass system for hot water if needed. Have fun mocking my indecision 😆 !!!!
@kilgorexv Hello, wouldn’t even think of mocking you! You make very good points and unfortunately for me, the search facility on RHH just doesn’t work at all well for me on an iPad but, there is at least one contributor who has written recently about the Daikin Multi + system and perhaps they will chip in soon. We have a Daikin ASHP and will be having Aircon from Panasonic fitted in late January / February. Neither system will heat our DHW however; we use a Sunamp Thermino unit for that as we did not have space for a 200+ litre DHW tank. Hoping the reader with the Daikin Multi + will be in contact to answer your questions soon though. Regards, Toodles.
I have mentioned Daikin Multi+ a few times as something for people looking at Air-to-Air (A2A) heat pumps but also wanting a solution for hot water to consider. I don't however have one myself. I do have a Daikin Perfera Air-to-Air 2.5kW and 3.5kW system, which I am very happy with. It was absolutely brilliant at keeping the house (a 146 sqm 4-bed detached) cool in the 5 heat waves this summer, despite only having one unit in the living room and the other in the main bedroom. Achieved performance on both heating (SCOP 5.2) and cooling (SEER 9.3) was as specified. It's made a big difference to our gas consumption by providing 6000 kWh of heating over last winter at around 2p per kWh of heat delivered (running on cheap rate overnight electricity or consuming what would otherwise be solar PV export). Total gas consumption is now 8000 kWh per year, compared to 14,000 kWh prior to A2A installation.
I would expect efficiency on both cooling and space heating to match the SEER and SCOP values quoted in the specification for Daikin and other A2A units. The reason for this is that A2A does not suffer the vagaries that A2W heat pumps do. There is no "flow temperature" that can be set differently, nor different weather compensation curves to play with, rather everything is self-contained and hence just works as specified, performance included. The installation for A2A is very straightforward with minimal disruption.
If your primary aim is not simply to get rid of gas altogether, then you might consider what is in effect a parallel hybrid system. Install A2A where needed - that might only be two units as we have, total cost around £4000. Use gas for all your hot water and share the heating load between A2A and gas CH. This could potentially be the best option in terms of economics, particularly as the standing charge for gas is going to disappear. It has the advantages of relatively low capital cost, substantial savings in annual running costs, cooling in summer, and redundancy in your heating system (if your gas boiler breaks down you can still use the A2A and vice versa).
It may prove impossible right now to get an MCS approved installer for the Daikin Multi+ and hence access the £2500 BUS grant that also requires removal of your gas boiler. As of Oct 2026, there are no MCS-certified installers for air-to-air heat pumps, although MCS expects certification to be available before the end of 2026 - see https://energysavingtrust.org.uk/advice/air-to-air-heat-pumps/. However, is unclear whether installers will want to incur the high costs associated with MCS certification given the relatively small grant available. The overheads added may be greater than the grant!
I would recommend finding three companies that have been in business many years fitting AC and air-to-air heat pumps, and get them to come and talk to you and get some quotes.
What is your annual gas consumption for hot water and central heating? Assuming that you keep your house at a comfortable temperature through autumn-winter-spring, you can get a rough but reasonable estimate of the heat loss, and hence the size of the heat source that you need by dividing annual gas usage by around 2000 to 2400. (For my house, 14000 / 2200 = 6.4kW, which is about right as confirmed by detailed heat loss calculations and also by plotting day-by-day gas usage versus indoor minus outdoor temperature difference and extrapolating from that).
Heat gain in summer can exceed by as much as a factor of two the heat loss in winter. However, in practice provided that you are prepared to close curtains on the sunny side of the house, matching the cooling to the heat loss is sufficient, for example 6kW of cooling is fine for our house.
Wow, thats a lot of cooling for two relatively small splits. My house is quite divided.... we have a 12m2 4m high double glazed conservatory facing south which need s alot of cooling in summer and a little heating in winter. My living room is 36m2 but u shaped with a chimney wall in the middle, so concerned about air flow and one end becoming a pocket!, then we have 3 bedrooms, the bathoom and the hall all at the other end of the bungalow. We are not young, although not derepit, but some cooler air in the summer for sleeping would make a huge difference. My current though is too many splits! I only use 9000 gas for everything, maybe 2000 for hot water, 300 for cooking and around 7000 for heating wuith a combi boiler 15 years old. My best cal for heat loss at -5 is about 4kw.
If you are willing to be pragmatic, then A2A with two indoor units will likely do a good enough job of keeping your house cool in summer and supplementing your gas heating in winter. Overnight, our gas CH is set back to 13C and so does not run, Instead, we run the A2A unit in the living room overnight on cheap rate electricity, effectively just dumping heat into the house at a set point around 2 degrees warmer than we need, using the fabric of the house as a sort of thermal store. This heat drifts around downstairs and also warms the stairwell and closest upstairs rooms (doors open). The gas CH then takes over during the day, with the A2A unit in the main bedroom adding a little more heat - we set the TRV on the radiator in there so that the A2A effectively switches off the central heating in that room. It's not perfect, but by running the gas heating during the day, we get even temperatures throughout the house. In summer, the A2A downstairs does the job well enough. Upstairs, where the heat naturally flows to, we make use of a desk fan placed on the floor to push some cool air out of the main bedroom into the upstairs hallway and the other bedrooms, its not perfect but good enough (24-26C in all the bedrooms when its 34C outside).
Another option that you could look at is a new development by Octopus called Cosy Cooler. If you got say an Octopus Cosy 6 air to water heat pump for which you can get the £7500 BUS grant, then Cosy Coolers can be added to it (once available). These are expected to cost £500-£600 each and are similar to portable AC units but connect to the radiator pipework and so shed heat via the Cosy heat pump rather than via a big ducting tube through a window.
https://octopus.energy/cosy-cooler/
Given that your boiler is 15 years old, that may be a better solution. The cooling won't be quite as good as dedicated single or multi-splits, but given they are meant for 20-30 sqm rooms, it should be good enough. At present there is very little info on efficiency, noise, etc. for Cosy Cooler. I would expect them to be similar to portable AC units, i.e. not that efficient, but annual energy use for cooling is nothing like that for heating, so that isn't necessarily an issue. (Our A2A did 640kWh of cooling output and 6000kWh of heating output in the last year).
@rob-of-york I saw a video about this, fortunately we are not in hurry. Will hang on and take a look.
Posted by: @rob-of-yorkI would expect them (Cosy Cooler) to be similar to portable AC units, i.e. not that efficient
I would have thought that they should be quite a lot better. Portable units have to draw moist, warm air into the house in order to balance the expelled air. The cosy cooler (and the similar Dutch product) keep the air in the house isolated because the hot side of the cycle is water cooled internally then external. However as you say it isn't that important.
For me personally the cosy plus cosy cooler is a better solution than hybrid A2A plus gas, because the heating (which is what the system is predominantly used for) is properly integrated. However I still would personally prefer a version of the cosy cooler that is wall mounted, replaces a radiator, and does both heating and cooling, so that the whole heating/cooling solution is fully integrated with a single control point. This is however a personal perspective based on personal priorities and others will differ.
- 2,815 Topics
- 2,070 Online
- 7,230 Members
By EtchedPixels , 1 hour ago
By Toodles , 4 hours ago
By Toodles , 6 hours ago
By EtchedPixels , 7 hours ago
By JamesPa , 7 hours ago
By Chilli304 , 11 hours ago
By JanHarley , 12 hours ago
By JamesPa , 15 hours ago
By bobflux , 1 day ago
