Midea M-thermal Mono ASHP - setting Schedule / Timer
Good morning. New member. Recently installed 16kW Midea M-thermal Mono ATW Heat Pump - - providing DHW and supply to both UFH & rads.
Seeking advice from more experienced members here.
My grid electricity is around 40% cheaper from 2330 - 0630 than daytime. We very rarely need 'hot' DHW after 2100. So .... obviously I can use my heating (UFH & Rads) controller to switch off demand in the evenings when the house is warmed up & grid electricity is 'expensive' - - but how do I do the same for my DHW ??
I have tried to use the 'Schedule / Timer ' options on the Midea wired controller - - but it is not clear to me how to achieve this
When I go into the controller Schedule panel it offers START and END times (clear enough!) but also requires MODE (HEAT / COOL / DHW) and TEMP.
My questions ->
* what is the best way to 'switch' off any DHW heating demand on my ASHP in the evenings ... delaying that demand until I have cheaper grid electricity at night ?
* is it to use the SCHEDULE functionality in the Midea controller ?
* if so, do I just need the TIMER screens ? ignore WEEKLY SCHEDULE ?
* what MODE should I set ? and what TEMP ?
* what happens to my system outside of times programmed into the SCHEDULE screens ? is it ' business as usual' ?
I look forward to your thoughts.
@dealstriker - welcome to the forum, and to the crazy world of the Midea controller.
I have my controller set up to have the DHW heating on between 1300 and 1400 every day (no time of use tariff, so use the usually warmer part of the day), and use just the Schedule > Timer screen, just one (first) row ticked, start 1300 end 1400 mode DHW temp 50 (same as on front page/main screen).
This does seem to work, but when I tried a while back to do something to time the heating to be off overnight, it didn't work. But, as I say, the single row DHW timer does work.
I think the Timer screen is just a global every day screen, the second Weekly Schedule screen is there to set different timings for different days of the week.
- 25 Forums
- 1,438 Topics
- 30.2 K Posts
- 34 Online
- 1,223 Members
RE: Air source heat pumps and noise
I could do you a video of these organic heat-pumps. I...
By Transparent , 2 mins ago
RE: Are You Getting the Most Out of Your Renewable Energy?
As I mentioned, there are going to be some follow-up ar...
By Majordennisbloodnok , 4 mins ago
Hmm. Looking at the images you posted, I'm interpreti...
By Majordennisbloodnok , 13 mins ago
RE: ASHP sizing - value of Heat Transfer Coefficient
@jancold The PCM is heated up by a 3 kW element in the ...
By Toodles , 31 mins ago
RE: Incorrect Billing of Customers with a Smart Meter
@korwraith can you please ensure that the information i...
By Transparent , 14 hours ago
Now, I know that this may be a little simplistic and pe...
By Toodles , 15 hours ago
I find increasingly staggering that the MCS rules don't...
By JamesPa , 16 hours ago
RE: Save the Energy Save the World using Daikin Altherma 3 operation mode and schedules settings.
Hello Mevl, I won't be able to answer all your question...
By HCas , 22 hours ago
RE: Spacing for roof fixing bolts ?
@heat-pump-newbie I don’t see why they shouldn’t show a...
I have been watching, with interest, the rebuild and re...
By iantelescope , 1 day ago
RE: Noise problems with newly installed Samsung 8kW ASHP
@elton, @kenbone has a lot of Samsung ASHP experience a...
RE: Making best use of Agile with a battery and ASHP
On the subject of automating battery charging schedules...
By jamesw , 1 day ago
Safety update; RCBOs supplying inverters or storage batteries
BEAMA have issued a safety update (March 2024) regardin...
Hanchu ESS - Home-ESS-LV9.4K (9.4kWh)
By IRMartini , 3 days ago
RE: Insulation of flow and return Heat Pump piping
@dr_dongle I saw a YouTube presentation from one of ins...
@editor Oh Mars, just as I was becoming interested … To...
It is certainly possible, using a modbus connection. If...
By cathodeRay , 4 days ago
I did another reconnection/ reconfiguration session wit...
By Abernyte , 5 days ago
RE: Recommended ASHP installers in Hampshire
@benson After my initial enquiries with Octopus, we had...
By Toodles , 5 days ago
Heat Pump Humour
Latest Topics
By heat-pump-newbie 3 days ago
By jamesw 3 days ago
By KoRWraith 5 days ago
Home energy storage & battery register
By Mars 6 days ago
Meter Readings - What are theses meters telling me?
By Potatoman 7 days ago
Have Octopus Energy discovered a way to Narnia?
By Davesoa 7 days ago
By jamesw 1 week ago
