Struggling to Find ...
[Sticky] Struggling to Find a Top Heat Pump Installer? We Can Connect You With the Best Installers in the UK
12 Users
15 Reactions
Posted by: @abam48
Hi all - I'm diving into the world of ASHPs and I am trying to source reputable installers in my area. I have used the chat bot and it has recommended Good Energy but they say they are not installing in my area. Leighton Buzzard - Bedfordshire. I have currently received a quote from Emerging Living Technology Heat which looks reasonable at first glance but hasn't gone into too much detail about the install - albeit they confirmed that they have initially designed the system for a flow temperature of 50 degrees which means that I wouldn't have to replace any rads in my property (it's a 1970s) build which I have insulated as much as I can. Current EPC rating of a C, which i've been advised is as high as we will be able to get it.
Quote is attached - would welcome feedback from experienced members.
Thanks in advance
Adam
My advice is reject unless they will delete the buffer tank.
Its also one of the cheaper heat pumps with some of the poorer inbuilt controls for not a particularly cheap price given that there is only 1 rad change.  Absolutely nothing wrong with the Samsung Gen6 as a heat pump but the UI is poor, controls relatively inflexible and many people fit Homely to supplement these.  Many people get away happily without Homely but I think you should seriously consider it if you go with Samsung.
Interesting that they are suggesting in the schematic to retain the existing DHW cylinder and plate loading it, something that I and a few installers have long advocated should at least be considered.  The proposal shows a replacement DHW tank however, doesn't say what size.
If they will delete the buffer tank and secondary pump then its worth pursuing to the next level else dont go there.
Designing for 50 isnt great but not a disaster, I would push them and anyone else to do an alternative design for 45 or less so you can compare.  Since most of the radiators are apparently already oversized for 50 its likely that it will require only a couple additional rad changes.  You might even be able to get down to 40!
Running at 45 and deleting the buffer tank will reduce running costs by 30%.
PS have you tried British Gas & Octopus.  They tend to do the simpler jobs but I would thing your house might well qualify.  Octopus can be very cheap if you can stand their purple unit.
PPS - a few ideas to find installers:
1. Contact the manufacturers and ask for the names of recommended/approved installers nearby.  Thats how I found mine in the end and he turned out to be less than a mile and a half away.
2. On the MCS website you can get a list sorted by distance.  Email those within 10-15 miles.  Tell them your rough requirements and pre-filter by saying that proposals involving a buffer, or any other separation between heat pump and emitters, will not be considered (2 port volumiser is OK).
3. Consider these guys. They operate through a network of partner plumbers; I know they have one in Cambridge with is likely close enough.  I went a long way down the path with Peter and Josh who clearly not only know their stuff but actually understand it.  They were very reasonably priced, no nonsense.  I would have gone with them, with considerable confidence, if I hadn't happened upon the guy a mile and a half away who was essentially offering the same proposition, but from a mile and a half away which is helpful for service!
This post was modified 8 months ago 8 times by JamesPa
This post was modified 8 months ago by Mars
3
(@abam48)
New Member Member
@jamespa Thanks for the advice - very helpful. I had already seen your numerous posts RE buffer tanks so that is something that I will keep a close eye on as I progress with design and installation. Will keep you posted once I've had a proper heat loss survey done and had a few alternative designs come through
(@seatonian)
Hi
New to the forums and still finding my way around.
Looking for some installer recommendations so have emailed you, Mars.
Out of interest, do any installers regularly engage on the Forum?
@seatonian got your email. Will connect you with a recommended installer tomorrow morning.
(@moman0311)
New Member Member
Hi Mars,
Have just joined the group. I am also looking for a recommended installer in my area. I have emailed you the contact details.
Keep up the good work! It is most helpful!
@moman0311 welcome to the forums. I've received your email and will connect you with some installers on Monday.
(@colinc)
Moving into a 2003 build, 186m²  property, and currently reading-in to the viability, hence inevitable design, of installing an ASHP to replace oil-fired CH/DHW with rads connected by 10mm 'plastic' u-bore (Natural Gas  is not an option in this Post Code of rural Devon), I'd be interested  to know information sources that compare metrics like operating temperatures and running costs.
The plan is to retrofit UFH in the  groundfloor; and to also augment energy with Solar PV & Battery which in itself is a design challenge (Trading/selling energy to grid is not an objective, self-use is)
 The house has EPC D. The heat loss estimate is 9.6kW (1st iteration spreadsheet, own calcs using MCS lookup tables.). Personal opinion is the heat loss might be overly high but cannot back this up with reliable data.
Informed opinion suggests air-changes is not a well understood or considered area in calculating heat losses. and wondering whether a 'pulse test' is a worthwhile exercise.
I have Mars' books, and welcome views.
This post was modified 2 months ago 3 times by colinc
Posted by: @colinc
There seems to be plenty of evidence to support this.  My measured loss is consistent with ach of 0.5-1 whereas the mcs calcs default to 2-3.  ashp system was designed based on measured loss and works.  If you can get an air change test done it's probably worthwhile.  I suspect your property may be 7kW or a bit less in reality.  My 1930s 200sq m property with partial fabric upgrades is 7kW,  I would hope that your insulation quality is better than mine!  My calculated loss based on mcs assumptions btw is 10.5kW.
You are planning ufh downstairs, what about upstairs.  You really want to design both to work at same flow temp without mixing so you can just operate open loop. Rads to run at 35 will be quite large and you may wish to consider fancoils.
You want a system that is as simple as possible for best performance.  No buffer, llh or heat exchanger between heat pump and emitters (2 port volumiser ok), no external controls, preferably run open loop on pure weather compensation or something very close.  Certainly not lots of zone valves/thermostats/trvs opening and shutting zones.
If the system is well designed running costs, ignoring the solar and batteries, should be similar to or a bit lower than gas if you can get your design temp down to say 40-45C.  Batteries and solar should improve further on this and if you can run at ufh temps (IE 35) better still.  Comfort should be far better.
Please feel free to ask any questions, there is quite a lot to understand.
This post was modified 2 months ago 5 times by JamesPa
dgclimatecontrol
(@dgclimatecontrol)
Estimable Member Member Professional Installer
@abam48 Did you go for this option and does it work well?
(@foxesfan)
New Member Member
I have a Nibe SMOS40, installed as a new build house in 2022.  The house runs radiators upstairs and underfloor heating downstairs.  We have a fair amount of south facing glass which on sunny days gives us a lot of solar gain.  The set up is one climate zone and I'm of the view after some research that the system should be a two zone configeration.
Having come to that conclusion I am really struggling to find an engineer / installer in Northamptonshire that understands heat pumps, Nibe, and the changes that will need to be made to my system to get to where I need to be.
I am hoping that someone on this forum would be able to recommend someone as I have been trying for some months.  The Nibe recommended installers have frankly been disappointing in their knowledge or response, and the company I have used to service my heat pump have charged me £240 without even removing the cover.
@foxesfan, welcome to the forums. I don't have anyone I can recommend in the Northamptonshire area. Hopefully there are members here in your neck of the woods that can recommend someone.
Also disappointing to hear about your £240 dud service!
@foxesfan Re: ‘Servicing’ as @editor has covered in his presentation, this servicing scam is widespread. I went to Daikin UK for my first two year’s Daikin Altherma services. In neither of these did the engineer put a screwdriver to the monobloc case! Even wnen they returned for a free ‘Special Annual Service’ to be carried out, they still did not check the inhibitor level as this is not in their remit!!!! You are not alone! Regards, Toodles.
Page 2 / 2
