Solar for heating DHW
Posted by: @davidalgarveJust tried to select "Quiet Mode" in advance of doing another 1 Hr, check whilst water heating and it reports "Invalid". Is there anything I can control that would unlock that?
That's odd, you should be able to set 3 or 4 levels of quiet in the installer menu.
Mitsubishis also have an Eco mode for DHW, you might want to try that instead?
@robs I have "Eco" already, but it was suggested that I should use Quiet in addition. Eco certainly reduced the power significantly, but nowhere near enough to get down to my 4 kW.
I am almost thinking that the 3kW immersion heater is a more useful option, but only if I can be sure of solar production.
2 x Growatt 7.5kW Batteries
Fronius EV Charger
Kia e- Niro 64kW
Did you manage to reduce power requirement for DHW?
Given warmer ambient temps I'm testing 'quiet mode' for DHW in isolation and findings suggest quiet mode in conjunction with DHW eco mode does reduce costs (in my case 20%) as you would expect. Given the number of variables wanted to check if others found the same?
One thing I missed early on was I had to extend the 'DHW mode switch delay' to immersion to allow for the delayed reheat.
Posted by: @davidalgarveI am almost thinking that the 3kW immersion heater is a more useful option, but only if I can be sure of solar production.
If you are thinking of heating on the immersion consider a solar diverter which precisely matches load to available power. I had one until I got an ashp and it worked a treat for 10+ years
However the cop is 1 no 2 or more so it's doubtful you will gain.
- 2,775 Topics
- 65.4 K Posts
- 3,893 Online
- 7,180 Members
By Batpred , 5 hours ago
Hi all, I'm new to this game having spent the last 25...
By gz00 , 7 hours ago
By Toodles , 11 hours ago
By tomasmcguinness , 16 hours ago
@mrkfm, I'd also suggest that whenever you're ready, st...
RE: Are you planning to use a wood burner to supplement your central heating this winter?
I use my stove daily for backup and comfort. Definitely...
By Margarethomas , 1 day ago
@rob-of-york Thanks. I wish I'd started on this site as...
By mrkfm , 1 day ago
@downfield I just checked this morning and OE just r...
Thanks Will. I'll probably be a week or so before get...
By Singlespeed , 2 days ago
From experience this summer, a single-split A2A unit on...
By Rob of York , 2 days ago
Analysis of the economics of switching to an A2W ASHP compared to other heat sources
This post aims to analyse the economics of installing, ...
By Rob of York , 3 days ago
@editor does that mean you have to have two separate ex...
By mrkfm , 4 days ago
