I have 178 L Gledhill unvented cylinder which was fitted in 2018 , which Google tells me has a heat exchanger surface area of 0.78 m².
I don’t really want the expense of changing it.
We have a fairly low demand for hot water, there are just the 2 of us, and my wife showers at the gym most of the time.
Over the summer I used 6 kWh of gas per day to heat the water.
I appreciate that it will take quite a lot longer to heat up the water, in Graham Hendras book there is a graph showing that it will take an hour to raise the water temperature from 20° to 40°C, as opposed to 20 minutes with a heat pump cylinder, this is with a flow temperature of 55°C.
I assume doing it this way would not cost any more, but if the flow temperature was increased to speed things up, then this would cost more.
An hour or more would be too long to leave the house heating off. Can the system be programmed to say heat the hot water for 15 minutes in every 60?
I intend to get solar panels and a battery, so apart from midwinter I would have my “own” electricity to heat the cylinder.
Depending on which installers I choose the heat pump will either be a Viessmann Vitocal 150A 12 or a Vaillant. Heat Geek would be installing the Vaillant. and they wanted an extra £2000 to change the cylinder. The installer who would fit the Viessmann said on the phone that it would be an extra £1000 to change the cylinder, he’s coming around next week to do the survey and give a firm quote.
I would be interested to hear the experiences of anybody who has had a heat pump installed and kept their old cylinder.
- 2,817 Topics
- 3,172 Online
- 7,230 Members
By David , 13 minutes ago
By EtchedPixels , 2 hours ago
By Toodles , 5 hours ago
By Toodles , 7 hours ago
By EtchedPixels , 8 hours ago
By JamesPa , 8 hours ago
By Chilli304 , 12 hours ago
By JanHarley , 12 hours ago
By JamesPa , 15 hours ago
By bobflux , 1 day ago
