Samsung/Joule Gen6
Welcome to the forums @isaac. What you’re describing is really common on systems that weren’t flushed properly at installation. We went through something very similar with our own heat pump, and the good news is that if you keep on top of cleaning the strainer, the issue usually settles down over time.
From the photo, it looks like you’ve got a mix of general sludge and early-stage corrosion. The sludge/gunk will clear with repeated cleaning (in our case it took around a dozen cleans before it finally calmed down) but any corrosion you’re seeing won’t go away on its own.
E911 on a Samsung is (from memory) a flow-related error, and it’s extremely common when the strainer starts to clog. If it’s reappearing after three or four days, I’d honestly be cleaning the filter once or twice a day for a little while just to get ahead of it.
Remember to keep an eye on your expansion vessel pressure.
Once the biological/algae-like sludge has stopped appearing, it’s worth getting a proper inhibitor/biocide into the system. This Fernox one works well with low-temperature systems: https://amzn.to/3MiBpr4
You can add it through a towel rail. There’s a strong chance your original installers didn’t dose the system at all, so get a bottle in now and then ask your installer to check the levels properly at your next service.
- 2,378 Topics
- 53.9 K Posts
- 289 Online
- 6,060 Members
As it turns out this is correct! All I needed to do was...
By benson , 24 minutes ago
@jamespa Do appreciate your assistance, without the ...
By Papahuhu , 2 hours ago
Here is an update of the setback we operate on our syst...
By SUNandAIR , 3 hours ago
RE: Grant ASHP 17.5 kw. weather curve
@chinkoa Sorry there are two separate thoug...
By JamesPa , 3 hours ago
@transparent As easy as putting sparklers in champag...
By Papahuhu , 4 hours ago
@f1p Looks good, and will likely be something I use whe...
RE: Cascade 2x Grant Areona 10kw ASHP - Ongoing setup issues
Either complete Bow Locks or at best a marginal effect....
By JamesPa , 9 hours ago
Hi all I’m looking to get some insight on what others...
By Renewables345 , 9 hours ago
RE: The Great British Heat Pump Owner Persona Survey: Let's Build Our Archetype!
@mosibi, go on then, complete the survey. Let's get the...
By Mars , 10 hours ago
RE: Water Hammer After Heat Pump Install
@jaynieq I wish you luck with this one. I think the ma...
By JamesPa , 12 hours ago
RE: Optimum new build house design for Heat Pump
From first principles I would say: Definitel...
As good a place as any to drop this video:/p>
@transparent D'Oh - I did look before I posted but I mi...
By dr_dongle , 1 day ago
Compatibility with Samsung AE080RXYDEH
I am new to all this. We have a SamsungAE080RXYDEH that...
By John999 , 1 day ago
@batpred Maybe you should buy your additional batter...
RE: Data Accuracy Problem: Daikin 8kW Heat Pump's Onecta App vs MMI Power Consumption
@nursethescreens Yes, comfort and happiness of the fami...
By Toodles , 1 day ago
Thanks folks. I had tried googling an ethernet lab adap...
By z8lccda , 2 days ago
RE: Changing from 4-port buffer to volumizer
@toodles I'm not concerned that the behaviour is not no...
By Andy1618 , 2 days ago
I agree, and I think there are two things in play here....
