[Solved] How to program setback (Ecodan 5.0)
@abernyte that is excellent. Very helpful. Thank you so much.
@abernyte Sorry, one more question. When setting for Room, Flow or Curve is it safe to assume that Room is Auto Adapt?
Just found this.
@afarmery did you ever resolve the issues you were battling with? Any updates would be appreciated.
Also, what is the size (kW) of your Ecodan?
- @editor I didn't resolve the issue really. My system is an Ecodan 5kW. I understand that it might be possible using Melcloud (but I'd need to buy an Ecodan WiFi adapter). In the end, I just implement setback manually. I've got the curve calibrated nicely to give room temps of about 19.5. The stats are set to 21, as a temp limiter. When I go to bed I nudge the curve down by 1 or 2 degrees on the FTC6 panel, then nudge it back in the morning. Power consumption is pretty meagre and I can mostly satisfy it with my solar panels and battery.
- 40 Online
By JamesPa , 41 minutes ago
@grahamf you appear to value your recirculating loop de...
By Judith , 51 minutes ago
By Judith , 1 hour ago
By Tasos , 4 hours ago
By Mars , 5 hours ago
By Scalextrix , 1 day ago
Inventor (Midea) Heat Pump short cycling advice
Hello, I have a Inventor (Midea) 8kW with a 800meters Φ...
By immunity , 1 day ago
By Old_Scientist , 1 day ago
By bontwoody , 2 days ago
By Alex , 2 days ago
By GrahamF , 2 days ago
By Morgan , 2 days ago
By DREI , 2 days ago
By Profzarkov , 2 days ago
By ASHP-BOBBA , 3 days ago
