Hitachi Yutaki SCombi Heat Pump - Owners
Does anyone on this forum own a Hitachi Yutaki SCombi Heat Pump? I need to find others and their experience of the system.
I would also be looking for a user specific forum for this pump, I drew a blank. Anyone know of one?
(Indoor Unit ) RWD-3.0RW1E-220S-K
(Outdoor Unit) RAS-3WHVRP1
2024 build bungalow
Southern england
179 m2
High level of insulation
Underfloor heating
All 12 circuits are fully open all the time
1 thermostat in family room
7KW heat pump
50 litre buffer tank (4 port)
3.6KW solar panels
Energy used by heating 2527 KWh - 7527 KWh (SCOP 3.5 approx)
@nick and @muscatblue have these units. Not sure if they're still active on these forums (they were last here in 2021), but because they've been tagged they should receive a message, so let's see if they return to help you.
@trebor12345, what was your question?
@editor I just wanted to know other owners thoughts and experience of this system. I am having issues with short cycles and getting steady flow temperature.
2024 build bungalow
Southern england
179 m2
Underfloor heating
7KW heat pump
3.6KW solar panels
Posted by: @trebor12345Does anyone on this forum own a Hitachi Yutaki SCombi Heat Pump? I need to find others and their experience of the system.
I've got a Hitachi Yutaki 11kW split system. Nothing but trouble and expense over the last 2 1/2 years. Hitachi customer support doesn't exist in the UK. Bosch has recently acquired Hitachi/Johnson Controls for all of Europe, so let's see what happens...
@sim0n0, increasingly strong anti-Hitachi messaging. Just goes to show how important manufacturer support is. Thanks for sharing.
Posted by: @sim0n0Posted by: @trebor12345Does anyone on this forum own a Hitachi Yutaki SCombi Heat Pump? I need to find others and their experience of the system.
Sim0n0. I also have the Hitachi Yutaki system. Also having lots of problems.
2024 build bungalow
Southern england
179 m2
Underfloor heating
7KW heat pump
3.6KW solar panels
Sorry to hear that. Putting the past aside would you like to describe the current problems and tell us a bit about your system and house in case we can offer support.
2024 build bungalow
Southern england
179 m2
Underfloor heating
7KW heat pump
3.6KW solar panels
@jamespa Hi James I appreciate the offer, but what I need is a local heat pump engineer familiar with Hitachi that can offer servicing/support. They don't exist and Hitachi doesn't have UK support. The original installers were useless (now Heat Geak certified), MCS certificate isn't worth the paper it's written on, and Hitachi/Hitachi engineers are non-existent in the UK.
- 2,391 Topics
- 54.2 K Posts
- 366 Online
- 6,074 Members
RE: Heat pump not reaching flow temperature
@majordennisbloodnok Its a Peak Energy Products V therm...
By johnd , 5 minutes ago
Seriously? So 'our heat pumps just work, we don't know...
By JamesPa , 11 minutes ago
RE: Ecodan with FTC7 - True Weather Compensation
Some data is definitely useful. I ordered the internet...
By JamesPa , 18 minutes ago
RE: Installer Fitted 9kW Instead of 11kW Heat Pump and Changed MCS Paperwork - What do I do?
So theres a problem for starters. This means that the ...
By JamesPa , 22 minutes ago
Each inverter would be limited to 16A export. But they ...
By Batpred , 2 hours ago
Worth also adding that, assuming you know the rough ove...
Daikin Atherma ASHP Cycling 6 Times an Hour?
I have a Daikin Atherma EDLQ07CAV unit and I've come he...
By John Marshall , 3 hours ago
My Cosy6 heat output was 116kWh yesterday, giving an av...
By AgentGeorge , 3 hours ago
@majordennisbloodnok This is some really good stuff. I ...
By Steelbadger , 15 hours ago
RE: Gen 6 Samsung ASHP losing 20C of DHW in 60 min directly after generation
Shouldn’t your temp sensor be in the middle or lowest s...
By EcoBaker , 17 hours ago
@batpred In all fairness you haven't provided any he...
By Bash , 17 hours ago
RE: Insulating a pitched roof with kingspan, has anyone done it?
Thank you everyone for all of the information, it looks...
By TRBob , 18 hours ago
@transparent Yep, they didn’t even mention it. When ...
By Papahuhu , 18 hours ago
Air source heat pump circuit not operational
Hi - need some advice about one circuit on my heating s...
By Plummersknowe , 19 hours ago
They are lovely, and I feel lucky to live in one, but t...
By cathodeRay , 19 hours ago
Worth adding that, for this tariff, the Octopus app has...
By Batpred , 20 hours ago
RE: APP for remote Daikin ASHP Operation
Thanks, @newhouse87. Understood. I was only asking on...
By Majordennisbloodnok , 21 hours ago
@mike-patrick A propos, I think my heat pump generates ...
By dr_dongle , 21 hours ago
RE: Mitsu Zubadan flow temperature issue
Update: The flow temperature has now stabilized at 60C ...
By bontwoody , 22 hours ago
