Ecodan high pressur...
Ecodan high pressure at 3 bar
4 Users
2 Reactions
(@sand)
We have a Mitsubishi Ecodan with UFH downstairs and radiators upstairs. The pressure at the water tank is 3 bar.
I have lowered this by bleeding water from the radiators to 2 bar as indicated by the fixed red marker on the pressure gauge.
This has gone back up to 3 bar and there is water coming from all the radiator bleed valves when opened so no air in them it seems.
We have had 2 new towel rails replacing cheap old ones. Not sure if this has anything to do with it.
Any advice on how I can resolve this issue and what might be causing it?
Andy
Topic Tags
(@dorkypark)
Something similar happened to me once with a gas system boiler. The filling loop hadn't been closed properly and it was pushing up the pressure over time. You might want to check that.
Posted by: @dorkypark
That's a good reason to disconnect the filling loop when not in use, in the way that it is designed for!
(@sand)
Hi thanks for that, I'm not sure  if I'm correct but I seem to remember having to open a valve to add pressure to the system. Would this be the valve that you mean? It was fully open and I've now closed it.
(@sand)
This is the valve I have closed is that correct, will I need to bleed rads again?
(@dorkypark)
Yes, you would need to reduce the pressure to the correct value for your system (usually 1 to 1.5 bar when cold).
And as @jamespa says, disconnecting the filling loop when not used is the correct thing to do.
(@sand)
Thanks, will do.
@sand I far as I am aware, all systems have two of these valves (one on each side of the mains feed to the red tank; these should both be shut off after any adjustment to pressure. (I may be wrong but all systems I have come across have the two valves and plumbers have told me they should both be shut after adjustments are complete.) Nervously, Toodles.
Posted by: @toodles
You are correct, but they also come with thumb-turn fittings so they can be disconnected easily.  On mine at least its necessary to do this to be sure that the shut off valve is truly shut off.
(@sand)
Thanks @toodles @jamespa will get hubby to check this.
