This particular example is one of the worst I have seen here. Uninsulated buried primaries!, uninsulated pipework around the cylinder, system separation, oversized heat pump, undersized radiators and doubtless some things we don't know about because they are masked.
The plumber who 'installed' this should be struck off! It's almost like they designed it not to work, but I doubt they were that competent. The lack of insulation would be equally bad if this were a boiler installation (worse in the case if the dhw tank, because it would be heated to a higher temperature), how were they ever let near this job. It makes one wonder about the rest of the plumbing.
3 months ago
3 months ago
Ecodan 11.2kw Wireless thermostat drop outs
3 months ago
Mitsubishi Ecodan System Pressure Changes - An Issue or Expected ?
4 months ago
Transforming a Derbyshire Property into an Energy-Efficient Haven
4 months ago
- 2,111 Topics
- 46.4 K Posts
- 6 Online
- 3,402 Members
@benson It is a shame, I was looking at these when I wa...
By Grantmethestrength , 8 hours ago
By Transparent , 8 hours ago
By Transparent , 9 hours ago
By Wh0am3ye , 11 hours ago
By marcinwloch69@gmail.com , 13 hours ago
When i was looking I encountered one installer who does...
By JamesPa , 14 hours ago
By TechnoGeek , 3 days ago
By seatonian , 5 days ago
By Toodles , 5 days ago
By JamesPa , 5 days ago
By ASHP-BOBBA , 5 days ago
By EcoBaker , 6 days ago
By Bart , 6 days ago
By Mars , 1 week ago
