Comms and power cabling to outside unit
Thanks for the link.
Posted by: @papahuhuI can only guess the issue is with cost of disposal or refilling. I know they also limit it to certain manufacturers too, I assume to the ones that BG fit themselves.
The pricing is a bit weird, it works out about £5 a month extra for break down cover above and beyond the service cost, for parts and labour I thought that was cheap as chips.
But the same cover for non warrantied systems is nearly £600 a year and has limits on part costs.
Yes, but that break down cover specifically excludes repair or replacement of your heat pump or controls, so only really includes your pipework and radiators (pumps, valves etc not within the heat pump box) that any plumber could repair, hence the low additional cost. Anything else would presumably be bounced back to the OEM for a warranty claim.
100%, the cover is for warrantied units only. How it works in practice is that in the event you wake up to no heating or DHW, call BG and they assign an engineer to diagnose fault. If the fault is outside of of ASHP or controls, they fix directly. If it is heat pump or controls, they liaise directly with, in our case, Samsung, and decide between them whom does the repair work. What I was told is that in the case of simple repairs, BG does it, for complex faults BG Samsung assign one of their specialist engineers.
(hope you are getting on well with flux, for me it’s been it’s worth nearly £100 a month on top of outgoing?)
- 2,820 Topics
- 66.9 K Posts
- 2,318 Online
- 7,232 Members
By the same measure we should be insisting that all gas...
By Batpred , 2 hours ago
True but .. because the room is colder dt rad to room i...
By JamesPa , 2 hours ago
Got two or three heat pump quotes that don’t agree? Post them here.
One of the biggest sources of confusion I see on Renewa...
By Mars , 2 hours ago
I do not disagree with the concept of wanting to live a...
By Batpred , 3 hours ago
@singlespeed I am going to put a temperature sensor on ...
By fosterl2 , 4 hours ago
RE: Grant Aerona - Weather Compensation and Schedules
@taffonthetaff Yes, I have now gotten to the bottom of ...
By bontwoody , 5 hours ago
Occasionally our Grant R290 activates all three circuit...
By TaffontheTaff , 6 hours ago
@davec 47kwh for 3 days is very low, compared to what I...
By johnd , 7 hours ago
By JamesPa , 11 hours ago
By Mars , 12 hours ago
Do heat pump defrost cycles impair heat pump efficiency (COP values)?
The short answer is no, as far as I can see from data f...
By cathodeRay , 12 hours ago
By Judith , 1 day ago
