- 2,418 Topics
- 54.8 K Posts
- 355 Online
- 6,098 Members
RE: Reliable, easy to use home battery options
@editor We had our Samsung Gen 7. 12 Kwh ASHP installed...
By Broadsman , 1 hour ago
RE: How to use my Hanchu battery storage for home without it feeding back into the grid?
Hi. My Hanchu battery system is controlled by the (Lux...
By SKD , 2 hours ago
RE: Ecodan Pump Issues… Circulation pump turns off when heat pump compressor turns off
Unfortunately it seems to be oversized. I can answer to...
By ASHP-BOBBA , 2 hours ago
RE: Installer Fitted 9kW Instead of 11kW Heat Pump and Changed MCS Paperwork - What do I do?
@jamespa thank you again. Apologies I missed you pointi...
By MairiA , 2 hours ago
In the Home Assistant firmware the data points...
By F1p , 13 hours ago
RE: GSHP WOES! Midland based engineer recommendations?
@johnbroome if it is not the pressure in the expansion ...
By ASHP-BOBBA , 13 hours ago
So I hear the export MPAN that UKPN assigned should be ...
By Batpred , 16 hours ago
From what I read, the Solis has a very long list of err...
RE: Ideal HP290 14kW ASHP - how to optimise
Roughly this should cost you £250-£300 per peak month a...
By ASHP-BOBBA , 17 hours ago
RE: New Daikin 11kW Altherma 3M install - is it working as it should?
@toodles Thank you for your input. As the days have got...
By Synthbuilder , 21 hours ago
RE: Fan unit Making terrible noise HELP!!
@gutoffowc Oh no, sorry to hear that, are you in the Ke...
By ASHP-BOBBA , 23 hours ago
RE: Sunsynk Whole House Backup Issue
@sheriff-fatman - could you please re-post that in the ...
By Transparent , 23 hours ago
RE: Running my new Nibe ASHP efficiently
I didn't. I spent a while manually messing around with ...
By jamieheatpumpnew , 1 day ago
RE: I’m glad the cold spell is over!
I comparison with the 65kWh used above yesterday was on...
By Judith , 1 day ago
I should think so, I thought that pretty much universal...
I'm also inclined to look into how a defrost is actuall...
By cathodeRay , 1 day ago
MLCP (Multi-Layer Composite Pipe) for ASHP
@editor nope. The info you reported was sufficient for ...
By iotum , 2 days ago
RE: Experience - New Build / Complete New Heating System
@vincro I would be surprised if it is much above 5 to 6...
By ASHP-BOBBA , 2 days ago
