Boxing in your cylinders.
I suppose that you could build a frame around all the equipment.
Just make certain that any electronic equipment is not exposed to high temperatures.
@marvinator80, the previous owners built a cupboard for our HW cylinder – it's a neat finish. You could probably do the same, but it might be a tight fit down the right (as I'm looking towards to your door) as it might touch the doorframe and possibly limit how much your door will be able to open.
@marvinator80, let us know what you decide.
looks like you could squeeze in some 12mm ply?
We have builders here just now due to the garage. Got them to have a look and they reckon it can be done!
You could also box off just the front and left side and hide it behind a curtain on the side by the door if there's not enough space there.
ASHP: Mitsubishi Ecodan 8.5kW
PV: 5.2kWp
Battery: 8.2kWh
You could do something with the door but clearly a bigger change
A more drastic solution is to reverse what looks like a back door and or fit a door a bit narrower if that would help.
Or have the door open out rather than in to the house. We have that on one of our doors in a utility room where room is tight
@marvinator80 WOW! Absolutely fantastic. Very tidy.
Out of interest, did your installer fit a low loss header and secondary pump or not? I don't see one there. I don't think single zone ASHPs need them, not with 15, 22 & 28mm piping or underfloor circuits. Grant tend to default to using them, they had some issues with retrofits using 10mm and mircobore which need a higher delta T over the emitters, and could not get the required flow higher delta T and lower rate through them compared to standard 15mm piped rads without hydraulic de-coupling of ASHP from heating circuit. It's a compromise solution in my mind.
- 2,149 Topics
- 47.1 K Posts
- 38 Online
- 5,667 Members
@jamespa or it might be related to the number of nuclea...
By IaAck , 19 seconds ago
I'm on Intelligent Go . Only since start of Feb. Before...
By Tim441 , 1 hour ago
@adamk apologies if my comments appeared thoughtless an...
By downfield , 3 hours ago
By GrahamF , 19 hours ago
By cathodeRay , 20 hours ago
I have heard of many people with a weakness for new car...
By cathodeRay , 1 day ago
By benson , 1 day ago
By Judith , 1 day ago
By TechnoGeek , 2 days ago
By Judith , 2 days ago
I’ve looked harder now (beyond OE’s site) and it’s not ...
By HCas , 4 days ago
By Old_Scientist , 4 days ago
By DavidAlgarve , 5 days ago
By SAEnergy , 5 days ago
By Temperature_Gradient , 6 days ago
